The PureCharge Cart 20 is part of the first family of charge-only solutions that are ready to go without the need to add cables or power adapters included with your devices. With the convenience of pre-installed Lightning cables and no setup required, the PureCharge products saves valuable time and money while freeing up cables and power adapters for use elsewhere in your deployment.
Simultaneous charge
Provides simultaneous charging for up to 20 devices. -
Ready to go
With pre-installed Lightning cables, simply plug in the cart and it's ready to go, right out of the box. -
Optimized cables
Cable clutter is eliminated through custom cables that are the optimal length for each slot and the right-angled Lightning connector makes it easy to connect devices. -
At-a-glance status
Without removing them from the slot, instantly determine which devices are fully charged via the individual charge status LEDs. -
Scalable
The PureCharge family of products is designed to grow with your organization. Stations can be stacked and the Cart 20 is upgradeable to 40 device slots.
- Bretford PureCharge Cart 20 HGFN2 cart - for 20 tablets - platinum powder
- Product Type
- Cart
- 92.2 cm x 55.4 cm x 97 cm
- 69.3 kg
- Recommended Use
- 20 tablets
- Outlets Qty
- 20
- Material
- Steel
- Platinum powder
- 7 years warranty
- 92.2 cm
- 55.4 cm
- 97 cm
- 69.3 kg
- Material
- Steel
- Platinum powder
AV Furniture
- Cart
- Recommended Use
- 20 tablets
- Cart Functionality
- Charge
- Output
- 2.1 A
- Outlets Qty
- 20
- Limited warranty - parts - cart - 7 years , Limited warranty - electrical components - 7 years
