Bretford PowerSync Roller 10 for iPad with Lightning
Quicklinx: B7FKWS00 Mfr#: HB718ZM/A
The PowerSync Roller provides full-rate charge, sync, protection and transport for up to 10 iPad with Retina display or iPad Air devices in a protected, hardshell rolling case.
On the move, the telescoping handle, inline skate wheels and interior foam padding provide a smooth and cushioned ride for your devices. And when you reach your destination, the PowerSync Roller's full-rate charge and simultaneous sync ensure your devices are ready to go.
Bretford PowerSync Roller 10 - rolling case for tablet
Rolling case for tablet
62.2 cm x 52 cm x 30.4 cm
14.5 kg
62.2 cm
52 cm
30.4 cm
14.5 kg
Carrying Case
Rolling case
Recommended Use
For tablet
Compartments Quantity
10 compartments
Telescopic Handle
USB cable, 2 combination locks, 10 Lightning to USB cables
Wheels, foam padding, hard shell, LED battery status indicator, power supply system, built-in 2 USB sockets
