The PowerSync Roller provides full-rate charge, sync, protection and transport for up to 10 iPad with Retina display or iPad Air devices in a protected, hardshell rolling case.
On the move, the telescoping handle, inline skate wheels and interior foam padding provide a smooth and cushioned ride for your devices. And when you reach your destination, the PowerSync Roller's full-rate charge and simultaneous sync ensure your devices are ready to go.
- Bretford PowerSync Roller 10 - rolling case for tablet
- Product Type
- Rolling case for tablet
- 62.2 cm x 52 cm x 30.4 cm
- 14.5 kg
- 62.2 cm
- 52 cm
- 30.4 cm
- 14.5 kg
Carrying Case
- Rolling case
- Recommended Use
- For tablet
- Compartments Quantity
- 10 compartments
- Telescopic Handle
- Included Accessories
- USB cable, 2 combination locks, 10 Lightning to USB cables
- Wheels, foam padding, hard shell, LED battery status indicator, power supply system, built-in 2 USB sockets
