Product
Bretford Generic Bretford PowerSync Cart for 30 iPads
Quicklinx: 8NSFWS00 Mfr#: H3635ZM/A
The Bretford PowerSync Cart for iPad stores, charges, syncs, and transports up to 30 iPad devices at a time. The PowerSync Cart for iPad will allow you to bring your iPad set - up to 30 devices - to any room in your building, and keep your content in sync with iTunes.
This design features a 30-device power system designed for iPad, providing full 2.1 A DC charging power to all iPad devices. And when connected to your Mac for syncing, the PowerSync Cart for iPad automatically switches over to a USB 2.0 mode.
  • Optimized charging power
    This design features the industry's first 30-device power system designed for iPad, providing full 2.1 A DC charging power to all iPad devices. And when connected to your Mac, the PowerSync Cart for iPad automatically switches over to a USB 2.0 mode for simultaneous syncing.
  • 30 iPads sync over 1 USB
    The PowerSync Cart for iPad allows you to sync up to 30 iPad devices with iTunes, moving all your selected apps, books, videos, music, and podcasts to each iPad, according to your specifications.
  • LED charge status overview
    While charging, the charge status LEDs, located on top of the cart, indicate the charge status of each group of 10 iPad devices. When all the iPads in a given group are charged, the corresponding LED will change from amber to green.
  • Laser-cut numbering system
    The PowerSync Cart for iPad features a laser-cut numbering system, helping you keep your iPads organized in the cart.
Bretford PowerSync Cart - cart
Cart
84 cm x 61 cm x 94 cm
76 kg
Recommended Use
30 tablets
12 years warranty
iPad 1; iPhone 3G, 3GS, 4, 4S; iPod touch (1G, 2G, 3G)
84 cm
61 cm
94 cm
76 kg
AV Furniture
Cart
Recommended Use
30 tablets
Limited warranty - 12 years
Apple iPad 1 , Apple iPhone 3G, 3GS, 4, 4S , Apple iPod touch (1G, 2G, 3G)
