Your basket is empty
Bretford Focus Cart 36 for Chromebook & Ultrabook
Quicklinx: B7FNWS00 Mfr#: INT-NETBOOK36-EU
Device Type: Laptop
£1,335.26 ex VAT
£1,602.31 inc VAT
The Bretford PowerSync Cart is the ideal solution for syncing and charging multiple Laptop Devices. The innovative design, the first of its kind, organizes, charges, and transports up to 40 Laptop devices, and provides a straightforward solution for syncing up to 20 Laptop devices at a time.
This version of the cart provides the same security, organization, charging, and syncing features that the PowerSync Cart for Laptop always has. But they added a few features and refinements to better serve your environment and organization. And right next to this shelf, you'll find a courtesy outlet for your MagSafe Power adapter. This feature allows you to secure your Laptop devices, and keep it charged up with your Laptops.
Device Type: Laptop
Brand: Bretford
Price Range Ex VAT: 1000 - 1500
