Product
Bretford 30 Unit MDM Laptop/Network Cart with Back Doors
Quicklinx: B7FSWS00 Mfr#: MDMLAP30-EU
The Bretford PowerSync Cart is the ideal solution for syncing and charging multiple Laptop Devices. The innovative design, the first of its kind, organizes, charges, and transports up to 40 Laptop devices, and provides a straightforward solution for syncing up to 20 Laptop devices at a time.
This version of the cart provides the same security, organization, charging, and syncing features that the PowerSync Cart for Laptop always has. But they added a few features and refinements to better serve your environment and organization. And right next to this shelf, you'll find a courtesy outlet for your MagSafe Power adapter. This feature allows you to secure your Laptop devices, and keep it charged up with your Laptops.
Bretford Basics 30 Laptop/Netbook Cart MDMLAP30 - cart
Cart
104 cm x 66 cm x 109 cm
Recommended Use
30 notebooks
Material
Steel
Aluminium, concrete powder
104 cm
66 cm
109 cm
Material
Steel
AV Furniture
Cart
Recommended Use
30 notebooks
Locking casters, lockable
