The little all-rounder: intelligent networking of traditional electrical appliances. The Plug Compact integrates traditional electrical appliances into your Bosch Smart Home System in a space-saving manner. Additionally, it expands the wireless signals of all HOME ZigBee devices, thus allowing previously unreached rooms to be connected.
Compact design
Small smart plug, big effect. Thanks to its compact design, the Plug Compact integrates traditional electrical appliances into the Bosch Smart Home System – without blocking other connectors. Ideal for narrow niches.
Save electricity costs
The timer simply switches unused devices on and off. You thus save electricity effectively and easily. Moreover, the integrated energy gauge measures the electricity consumption of the connected devices continuously and precisely
Wards off burglars
The Plug Compact enables the automated control of all lamps and electrical appliances, thus complementing your presence simulation – for even more effective protection from burglars.
Switch on and off using voice command
Once integrated, you can control your intelligent socket in various ways: by your fingertip in your app or via speech assistants such as Alexa or Google Assistant.
Box contents
- 1 Plug Compact
- 3 Quick Start Guides
Compact design
Small smart plug, big effect. Thanks to its compact design, the Plug Compact integrates traditional electrical appliances into the Bosch Smart Home System - without blocking other connectors. Ideal for narrow niches. -
The timer simply switches unused devices on and off. You thus save electricity effectively and easily. Moreover, the integrated energy gauge measures the electricity consumption of the connected devices continuously and precisely. -
Extend range
The Plug Compact acts as a wireless signal strengthener for Twinguards, Motion Detectors, Twists, Water Alarms and other Plug Compacts. You thus integrate even previously unreachable rooms into your Smart Home System. -
Helps to save energy
The Plug Compact measures the current and total energy consumption of your electrical appliance. It thus contributes to an energy-saving lifestyle. Integrated into automations, your little Smart Home socket triggers certain actions in the event of changes to the electricity consumption of your devices. You thus know when the washing machine is finished or your eBike is charged. -
Compact and efficient
Do you want to connect your lamp and your coffee machine to a double socket? Thanks to the compact design compared to other wireless sockets, several Plug Compacts can be used side-by-side without blocking each other. -
Increases the range
The Plug Compact allows you to connect previously unreachable rooms on a smart basis. The smart socket has a function to strengthen the wireless signal of your Twinguards, Motion Detectors, Twists, Water Alarms and other Plug Compacts. -
Wards off burglars
The Plug Compact enables the automated control of all lamps and electrical appliances, thus complementing your presence simulation - for even more effective protection from burglars. -
 - Bosch Smart Home Plug Compact BSP-GZ2 - smart plug - ZigBee 3.0
- Product Type
 - Smart plug
- Power Source
 - Integrated power supply
- Connectivity
 - Wireless - ZigBee 3.0
- Frequency Band
 - 2.4 Ghz
 - 2-year warranty
 - 6.37 cm x 5.85 cm x 5.85 cm
- Product Type
 - Smart plug
- Power Source
- Connectivity Technology
 - Wireless
- Frequency Band
 - 2.4 Ghz
 - Up to 2300 Watt
- Voltage Required
 - AC 230 V
- Warranty
 - 2-year warranty
 - 1 Watt
 - IP20
 - 6.37 cm
 - 5.85 cm
 - 5.85 cm
 - 126 g
- Shipping Width
 - 9.2 cm
- Shipping Depth
 - 9.1 cm
- Shipping Height
 - 10.3 cm
 - -5 °C
 - 35 °C
