Your basket is empty
Boompods Powerpod Portable Charger 2300mAh (Lightning) - Green
Quicklinx: BSXLWS00 Mfr#: PPIGRN
  • Recharge your phone on the go. A functional pocket size charger with no messy cables.
  • Its compact and lightweight design has an integrated flip-out power line to connect to your phone.
  • Check the charge level using the handy indicator, the 4 LED lights show the charging status and stored power.
  • Charges through a standard USB port and uses a 2300mAh rechargeable LiPo battery technology that will repower your phone anywhere.
  • Features a power-down mode so if left on with no device connected, it will shut down automatically after 30 seconds to ensure the battery power is preserved for maximum usage.
  • Colors: available in matt black, white, blue, orange and green with a soft touch finish.
Boompods POWERPOD power bank - Li-pol
Power bank
2.5 cm
Diameter
6.5 cm
Output Connector Type
Lightning
Lithium polymer - 2300 mAh
1 year warranty
Power bank
2.5 cm
Diameter
6.5 cm
Enclosure Colour
Green
Input Connectors
5 pin Micro-USB Type B (power only)
Input Connectors Qty
1
Output connectors
Apple Lightning
On/off button
Lithium polymer
2300 mAh
Recharge Time
3 hour(s)
Battery level indicator
Micro-USB charge cable
FCC, RoHS 2002/95/EC
Limited warranty - 1 year
