With its compact and tactile design, the maxpod portable recharger is an ideal portable backup battery pod for phones, tablets and USB devices.
Charges through 2 smart charging ports and uses a large 5200mAh rechargeable Lithium-ion battery technology that will repower your phone, tablet or MP3 on the go.
Check the charge level using the handy indicator, the 4 LED lights show the charging status and stored power.
Features a power-down mode so if left on with no device connected, it will shut down automatically after 30 seconds to ensure the battery power is preserved for maximum usage.
- Boompods MAXPOD power bank - Li-Ion - USB
- Product Type
- Power bank
- 3.6 cm
- Diameter
- 8.5 cm
- Black
- Output Connector Type
- Total 2: USB - on cable: Micro-USB
- Battery
- Lithium Ion - 5200 mAh
- Cables
- Micro-USB to USB cable
- 1-year warranty
- Product Type
- Power bank
- Designed For
- Portable player, tablet, mobile phone
- 3.6 cm
- Diameter
- 8.5 cm
- Enclosure Colour
- Black
- Input Connectors
- 5 pin Micro-USB Type B
- Input Connectors Qty
- 1
- Output connectors
- Total 2: 4 pin USB Type A
- Detachable Cable Connector Type
- Micro-USB Type B
- LED indicator
- Technology
- Lithium Ion
- Capacity
- 5200 mAh
- On/off button
- Cables Included
- FCC, RoHS
- Limited warranty - 1 year
