Product
Brand
Boompods Maxpod Portable Charger 5200mAh - Blue
Quicklinx: BSXJWS00 Mfr#: MXPBLU
With its compact and tactile design, the maxpod portable recharger is an ideal portable backup battery pod for phones, tablets and USB devices.
Charges through 2 smart charging ports and uses a large 5200mAh rechargeable Lithium-ion battery technology that will repower your phone, tablet or MP3 on the go.
Check the charge level using the handy indicator, the 4 LED lights show the charging status and stored power.
Features a power-down mode so if left on with no device connected, it will shut down automatically after 30 seconds to ensure the battery power is preserved for maximum usage.
Boompods MAXPOD - power bank Li-Ion
Power bank
3.6 cm
Diameter
8.5 cm
Output Connector Type
USB - on cable: Micro-USB
Lithium Ion 5200 mAh
Cables
Micro-USB to USB cable
1 year warranty
Power bank
3.6 cm
Diameter
8.5 cm
Enclosure Colour
Blue
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Output connectors
Total 2: 4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
LED indicator
Lithium Ion
5200 mAh
On/off button
FCC, RoHS
Limited warranty - 1 year
