Product
Blue Microphones Yeti Pro - Microphone - USB
Quicklinx: 91ZQWS00 Mfr#: 836213001967
More than 50 in stock
£244.28 ex VAT
£293.13 inc VAT
Ultimate microphone for professional USB & XLR recording.
The Yeti Pro is the world's first USB microphone combining 24 bit/192 kHz digital recording resolution with analog XLR output. Featuring three custom condenser capsules and four different pattern settings, the Yeti Pro can capture digital audio with up to four times the clarity found on CDs. Plus, the Yeti Pro features a cutting-edge A-D converter chip and separate analog circuit path for use with professional studio mixers and preamps. You also get a built-in headphone amplifier for zero-latency monitoring, and direct controls for headphone volume, pattern selection, mute, and microphone gain. So whether you record at home, in a studio (or in the Himalayas!), the Yeti Pro is your ultimate sound solution.
Legendary features.
The legend of the Yeti continues with the most advanced and versatile multi-pattern USB microphone roaming the wild today. The Yeti Pro features tools and recording capabilities usually requiring multiple microphones and devices, all with the simplicity of a plug 'n play USB microphone.
Settings
  • Stereo - The Stereo mode is great for capturing a realistic stereo image. To start, point the microphone at the sound source that you want to record (the "front" of the microphone is the side of the microphone with the Blue Microphones Logo). Depending on the instrument and/or sound that you want to achieve, place the grill of the microphone anywhere from 2 inches to several feet in front of the sound source. By centering the sound source, you will get equal amounts of signal in both the left and right channels. If you want a little more of the signal in the right channel, move the sound source a little to the right side of the mic (as if one is behind the microphone), and if you want a little more of the signal in the left channel, move the sound source to the left (as if you are behind the microphone). Alternatively, you can record everything as centered as possible, and easily adjust the position when you're mixing the recording. If you want the sound in the right or left channel only, you should try using the cardioid, bidirectional or the omnidirectional setting, and use your software to hard-pan the sound to the left or the right.
  • Cardioid - Cardioid is the most commonly used mode and can be useful in most any situation. If you are recording vocals, a podcast, or a voiceover, cardioid is likely your best choice. When recording in cardioid, sound directly in front of the microphone is picked up while the sound at the rear and sides of the microphone is not picked up. Therefore, you will want to arrange the source directly in front of the microphone. Cardioid will deliver the most direct, rich sound, but will not offer as much airiness or presence as the other recording modes.
  • Omnidirectional - Omnidirectional means that the microphone picks up sound equally from all directions. This setting is perfect for recording a group of musicians all playing at the same time, recording a conversation between multiple parties around a room, a conference call, or any other situations where you want to capture the ambience of 'being there.' Because sound is picked up from all directions in this mode, the orientation of the microphone isn't crucial, but as a good rule of thumb, start by orienting the front of the microphone at the primary sound source you wish to record.
  • Bidirectional - Bidirectional means that the microphone picks up sound at the front and rear of the microphone, while the sounds to the sides are "rejected", or not picked up. The bidirectional setting is very useful in achieving a nuanced, pleasant sound when recording musical instruments, and is perfect for recording an interview with two or more guests. By placing the microphone between two or more subjects (front of microphone facing one source, rear of microphone facing another), you can achieve a natural sound without the complexity of using multiple microphones.
Yeti Pro Technical Specifications
Microphone and Performance
  • Power Required/Consumption: 5V 500mA (USB)/48V DC (analog)
  • Sample Rate: 192 kHz
  • Bit Rate: 24bit
  • Capsules: 3 Blue-proprietary 14mm condenser capsules
  • Polar Patterns: Cardioid, Bidirectional, Omnidirectional, Stereo
  • Frequency Response: 20Hz - 20kHz
  • Sensitivity: 4.5mV/Pa (1 kHz)
  • Max SPL: 120dB (THD: 0.5% 1kHz)
Headphone Amplifier
  • Impedance: >16 ohms
  • Power Output (RMS): 130 mW
  • THD: 0.009%
  • Frequency Response: 15 Hz - 22 kHz
  • Signal to Noise: 114dB
  • Dimensions (extended in stand): 4.72"(12cm) x 4.92"(12.5cm) x 11.61"(29.5cm)
  • Weight (microphone): 1.2 lbs (.55 kg)
  • Weight (stand): 2.2 lbs (1 kg)
  • Cable: 12" Y-Cable and 2M USB cable
  • PC: Windows 8, Windows 7, Windows Vista, XP Home Edition or XP Professional
  • USB 2.0 High Speed; 256 MB RAM (minimum)
  • Requires downloadable driver
  • Macintosh: Mac OSX (10.6.4 or higher)
Blue Microphones Yeti Pro - microphone
Microphone
Recommended Use
Professional audio, computer - recording
Additional Functions
Amplifier
Microphone
External
Microphone Operation Mode
Stereo
Controls
Mute, volume
2 years warranty
Microphone
Amplifier
12 cm
12.5 cm
29.5 cm
550 g
Recommended Use
Microphone
Stereo
Wired
Frequency Response
20 - 20000 Hz
Total Harmonic Distortion (THD)
0.5%
Max Sound Pressure
120 dB
Audio Input Details
Cardioid - 20 - 20000 Hz , Omni-directional - 20 - 20000 Hz , Bi-directional - 20 - 20000 Hz
Remote Control
Controls
Mute, volume
Connector Type
USB , Microphone (5 pin XLR) , Headphones (mini-phone 3.5mm)
USB cable - 2 m , Microphone cable - 30.5 cm
Microphone stand
RoHS
Brand: Blue Microphones
Price Range Ex VAT: 150 - 300
