Introducing Nessie - the first adaptive USB mic for fearless recording
Nessie takes the fear out of great recording by instantly delivering studio-enhanced sound for desktop recording of vocals, instruments, voice overs and more.
Designed to combat the most common pitfalls of recording, Nessie automatically adapts to whatever you're recording, applying professional studio processing combined with a built-in pop filter and internal shockmount, to produce expertly finished sound, without the need for additional mixing or editing. Just as the latest point-and-shoot cameras will reduce redeye and automatically adjust focus and exposure for improved photos, Nessie professionally enhances audio so that you get polished music demos, podcasts, interviews, YouTube broadcasts and more, instantly!
The built-in, studio-grade pop filter and shock mount reduce harsh plosives and disruptive rumbling and vibrations, while the adaptive processing, including EQ, de-esser and level control, automatically smoothes and refines your audio in real time.
No matter what you want to record, Nessie takes the guesswork out of great recording!
Nessie's three flexible recording modes are optimized for richer vocals, more detailed instruments or an option for raw audio for manual post-production editing. Nessie employs a single custom-tuned condenser capsule with a cardioid pattern.
Nessie also features a zero-latency headphone output for direct monitoring, which is critical for eliminating distracting delay, while headphone volume and instant mute are located directly on the microphone. For optimal positioning, Nessie's head adjusts with serpentine flexibility. Nessie is Plug-and-Play compatible via USB with both PC and Mac with driverless installation. For mobile recording, you can connect Nessie to iPad using Apple's camera adapters and a powered USB hub, both sold separately.
Nessie's key features and internal processing are specifically designed to combat the most common pitfalls of recording. The built-in, studio-grade pop filter and shockmount reduce harsh plosives and disruptive rumbling and vibrations, while the adaptive processing, including EQ, de-esser and level control, automatically smoothes and refines your audio in real time. Nessie employs a single custom-tuned condenser capsule with a cardioid pattern. Nessie's three flexible recording modes are optimized for richer vocals, more detailed instruments or an option for raw audio for manual post-production editing. Nessie features a zero-latency headphone output for direct monitoring, while headphone volume and instant mute are located directly on the microphone. For optimal positioning, Nessie's head adjusts with serpentine flexibility. Nessie is plug-and-play compatible via USB with both PC and Mac.
Nessie Technical Specifications
Microphone and Performance
- Power Required/Consumption: 5V 150mA
- Sample Rate: 48 kHz
- Bit Rate: 16bit
- Capsules: 1 Blue-proprietary 14mm condenser capsule
- Polar Patterns: Cardioid
- Frequency Response: 20Hz - 20kHz
- Max SPL: 110dB (THD: 0.5% 1kHz)
Headphone Amplifier
- Impedance:16 ohms
- Power Output (RMS): 100 mW
- THD: 0.009%
- Frequency Response: 15 Hz - 22 kHz
- Signal to Noise: 100dB
- Dimensions (in stand, home position): 3.75"x 3.75" x 10"
- Dimensions (max extension): 3.75"x 3.75" x 11.25"
- Weight (microphone in stand): 1.4 lbs (.64 kg)
System Requiements
- PC: Windows 8, Windows 7, Windows Vista, XP Home Edition or XP Professional, USB 1.1/2.0; 64 MB RAM (minimum)
- Macintosh: Mac OSX ( 10.4.11 or higher ), USB 1.1/2.0, 64 MB RAM (minimum)
Built-in sound engineer
Nessie is a smart USB microphone. In fact, it automatically applies fundamental recording processes - such as EQ, de-essing, compression, and level control - in real time to instantly enhance your audio. -
Everything you need in one package
No one wants to hear those two dreaded words "sold separately". That's why Nessie has everything you need to make expert recordings. Nessie comes fully loaded with professional studio processing tools to contour your sound during any recording application. -
Focus on your performance
Bring Nessie into your home studio and take the guesswork out of recording. Zero-latency monitoring eliminates distracting delays, while easy-access headphone volume and instant mute aid in fine-tuning your recording or broadcast workflow.
- Blue Microphones Nessie - microphone
- Product Type
- Microphone
- Recommended Use
- Professional audio - instrument, vocal, voice, recording
- Additional Functions
- Amplifier
- Microphone
- External
- Microphone Technology
- Electret condenser
- Microphone Operation Mode
- Cardioid
- Controls
- Mute
- 2-year warranty
- Product Type
- Microphone
- Amplifier
- 9.53 cm
- 9.53 cm
- 25.4 cm
- 640 g
- Recommended Use
Microphone
- Cardioid
- Connectivity Technology
- Wired
- 20 - 20000 Hz
- Signal-To-Noise Ratio
- 100 dB
- Total Harmonic Distortion (THD)
- 0.5%
- Max Sound Pressure
- 110 dB
Remote Control
- Controls
- Mute
- Connector Type
- USB
- RoHS
- Limited warranty - 2 years
