Product
Brand
BlackBerry Mains Charger Bundle AC-1300UK 1.2M Micro-USB Cab
Quicklinx: BN9MWS00 Mfr#: ACC-59826-001
Get maximum convenience in a minimum space using the BlackBerry USB Power Plug. The slim design uses up less space on wall outlet/power bars versus traditional chargers. Designed for maximum portability - it's easy to travel with. By charging your BlackBerry smartphone quickly, you'll be able to keep your smartphone ready virtually wherever you go.
BlackBerry power adapter
Power adapter
Output Connector Type
USB - on cable: Micro-USB
Power adapter
Output connectors
4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
Max Electric Current
1.3 A
Micro-USB cable
