BitFenix Shinobi Gaming Case USB 3.0 Black
Quicklinx: 9KG0WS00 Mfr#: BFC-SNB-150-KKN1-RP
Named after some of the most feared assassins of the modern age, Shinobi empowers the digital warrior to silently and efficiently dispatch his opponents. Maximum expansion and compatibility with long graphics cards enables you to equip Shinobi with the tools you need to get the job done. Superior cooling options allow the system to stay cool and collected during the heat of battle, while a sophisticated yet understated styling shows the opposition you mean business.
  • Killer looks
    From the uniquely crafted side panel window and fan vents, to the brushed aluminum accents, Shinobi Window carries through the signature BitFenix design philosophy of clean lines, understated elegance, and modern styling. If looks could kill, a glance at Shinobi Window could be your last.
  • Choose your destiny
    The stealthy digital warrior must adapt to their environment. Available in with or without a windowed side panel, you can choose the Shinobi that blends perfectly with your surroundings. Whether you choose to walk the path of light or darkness, Shinobi has you covered.
  • Maximum expansion
    Serious rigs require serious hardware. That's why Shinobi Window is engineered to handle up to three 5.25" drives or eight 3.5" hard disks. You can also install a 2.5" SSD with the included adapter. Best of all, Shinobi Window can easily accommodate long graphics cards, which means that you can outfit it with the hardware necessary to eliminate the opposition.
  • Plenty of connectivity
    The efficient warrior must have easy access to all the tools they need to get the job done. Equipped with no less than four USB 2.0 ports, Shinobi Window offers plenty of connectivity for all your USB devices so that you can keep you gear connected and ready for battle.
  • DIY friendliness
    Fighting should be done in game - not with your hardware. Shinobi Window comes with a wealth of DIY-friendly features, ensuring that getting your system setup is quick and efficient. A CPU cooler cutout makes it easy to change out your CPU cooler should the need arise. Shinobi Window comes with filtered fan intakes, keeping the interior clean and your system looking great. Shinobi Window even comes with convenient tool-free drive locking mechanisms for ultimate convenience.
  • BitFenix quality
    Shinobi Window comes with all the amenities and design touches characteristic of BitFenix chassis. BitFenix SofTouch surface treatment for resistance to fingerprints and stains surrounds the brushed gunmetal BitFenix logo emblazoned on the front. A luxuriously black coated chassis exudes both quality and refinement. With Shinobi Window, users can experience BitFenix quality both inside and out.
BitFenix Shinobi - tower - ATX
System cabinet
Tower
I/O Connectors
4 x USB 2.0 , 1 x microphone , 1 x headphones
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Screwless drive bays
No power supply (ATX / PS/2)
20.5 cm x 49 cm x 46 cm
Tower
Max Mainboard Size
ATX
Internal Bays Qty
8
Front Accessible Bays Qty
3
Cooling System
Front: 120 mm fan mount x 2 / intake , Rear: 120 mm fan x 1 / exhaust / 1 x 92 mm fan supported , Top: 120/140 mm fan mount x 2 , Bottom: 120 mm fan mount x 1
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 8 (total) / 8 (free) x internal - 3.5" , 1 (total) / 1 (free) x internal - 2.5"
Expansion Slots
7 x Expansion Slot
4 x USB 2.0 , 1 x microphone - mini-jack , 1 x headphones - mini-jack
5.25" to 2.5" bay adapter
No power supply
Specification Compliance
ATX / PS/2
20.5 cm
49 cm
46 cm
