Meticulously crafted and beautifully engineered, Prodigy redefines the Mini-ITX chassis. The compact housing is suspended by handles made with BitFenix FyberFlex Composite for easy portability and maximum shock absorption. On the inside, our modular FlexCage gives you the flexibility to install up to five 3.5" hard disks or 2.5" SSDs, or remove it entirely to fit up to 240mm watercooling radiators and long graphics cards. For added flexibility, additional SSD locations are also included, and a choice of Midnight Black or Arctic White with interchangeable front facades mean Prodigy will suit your individual style. With tool-free convenience, two USB 3.0 ports, filtered intakes, and proprietary BitFenix SofTouch Surface Treatment, Prodigy is the compact case with no compromises.
Beautifully Compact
With its subtle curves and clean lines, Prodigy is distinctly BitFenix. The compact mini-ITX body is suspended by two elegantly crafted handles that give Prodigy a solid yet modern look that makes it a perfect addition to any environment. -
Unmatched Flexibility
Despite its small stature, Prodigy is engineered for maximum flexibility. Remove the top HDD cage to fit long graphics cards up to 320mm in length. Bolt a 240mm water cooling radiator in the top, or if the build demands it, remove the entire HDD cage and put the 240mm radiator in the front, while still being able to install up to five 2.5" drives. With multiple installation options, Prodigy is a small case that truly does it all. -
FyberFlex Composite Technology
Both the top and bottom handles of Prodigy are made from BitFenix FyberFlex Composite - a revolutionary material that is not only flexible, but incredibly strong. Fastened on both the top and bottom of the chassis, these handles are a convenient way to carry Prodigy, while providing added shock absorption during transport. -
Maximum Storage Potential
With the ability to install up to five 3.5" HDDs or nine 2.5" SSDs, Prodigy provides loads of storage options. Set it up as a high octane portable gaming rig, an attractive home server, or a full on NAS. With Prodigy, the possibilities are nearly limitless. -
Choose Your Own Style
Your computing environment is your own space, which is why everything in it should be uniquely you. Prodigy comes in both Midnight Black and Arctic White, making it a perfect fit just about anywhere. -
Ready for DIY
To get you up and running in the shortest possible time, Prodigy is loaded with DIY-friendly features. The unique motherboard tray makes it easy to fit tall CPU coolers, and filtered fan intakes keep the interior and system looking superb. Finally, the Prodigy's tool-free drive locking mechanisms make installing HDDs an incredibly simple affair, while cable management features keep your internals neat and tidy. -
High-Speed USB 3.0 Connectivity
Got large files you need to transfer? No problem. Equipped with two SuperSpeed USB 3.0 ports, Prodigy allows you to transfer files ten times faster than with USB 2.0. -
BitFenix Quality
As a BitFenix chassis, Prodigy comes with all the extra touches fans have come to expect from BitFenix. Our FyberFlex handles are coated with none other than BitFenix SofTouch surface treatment, while the luxuriously coated interior and rolled-edge cable pass-throughs exude a premium feel.
- BitFenix Prodigy M - tower - micro ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Vivid green
- I/O Connectors
- 2 x USB 3.0 , 1 x audio line-out , 1 x audio line-in
- Supported Motherboards
- microATX, Mini-ITX
- System Cabinet Features
- Carrying handle, SofTouch coating, interior painting
- Power Device
- No power supply (ATX / PS/2)
- 25 cm x 35.9 cm x 40.4 cm
- Form Factor
- Tower
- Max Mainboard Size
- Micro ATX
- Vivid green
- Cooling System
- Top: 120 mm fan mount x 2 / intake , Bottom: 120 mm fan x 1 / 1 x 230 mm or 1 x 200 mm or 2 x 120 mm fan supported , Rear: 120 mm fan x 1 / exhaust / 1 x 120/140 mm fan supported
- Expansion Bays
- 1 (total) / 1 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x internal - 2 x 2.5"/3.5" shared , 2 (total) / 2 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5"
- Expansion Slots
- 5
- Power Device
- No power supply
- Specification Compliance
- ATX / PS/2
- 25 cm
- 35.9 cm
- 40.4 cm
