Billion Wireless 'N' Firewall ADSL2+/Broadband Router
Quicklinx: 7RK8WS00 Mfr#: BiPAC 7700N
  • IEEE 802.11n
An affordable wireless 'N' modem/router that offers increased wireless coverage and faster wireless speeds with 2T x 2R technology (2 transmit/2 receive), as well as rock-solid, fast Internet access via your ADSL line, with download speeds up to 24 Mbps with ADSL2+, incorporating WPA2 encryption for optimum wireless security and a SOHO firewall and QoS. In addition an Easy Install CD provides a hassle-free set-up experience - ideal for the home user.
Features:
* High speed internet access with ADSL2/2+ Broadcom chipset integrated with 4-port Ethernet Switch
* Faster downloads, extra stability, good on long lines
* 300 Mbps Wireless AP with WPA / WPA2 support 'N'
* Easy set-up CD included
* Firewall Security with DoS Prevention and Packet Filtering, QoS
* Ideal for Home and SOHO Users
  • Optimal wireless speeds and coverage
    Utilizing the benefits of Wireless N technology, BiPAC 7700N performs faster file transfers and farther coverage enabling greater wireless signals across your home. If the network requires wider coverage, the built-in Wireless Distribution System (WDS) repeater function allows users to expand the wireless network without the need for any external wires or cables. Upgrading your home network to Wireless N provides an excellent solution for experiencing better wireless performance while sharing a broadband Internet connection with multiple computers over a secure wireless network.
  • Quality transmission enhances Internet experience
    Quality of Service (QoS) gives full control over outgoing data traffic. Priority can be assigned by the router to ensure that important transmissions like gaming packets, VoIP calls or IPTV/streaming content passes through the router at lightning speed, even when there is heavy Internet traffic. The VLAN support is also capable of establishing reliable high-speed transmissions for wide bandwidth applications such as IPTV, VOD, or online gaming without consuming bandwidth.
  • High-speed Internet access
    The BiPAC 7700N is compliant with worldwide ADSL standards. The integrated Annex M standard supports ADSL2/2+ for higher uploads by doubling the upload data rate. The 4-port Ethernet switch incorporated into the BiPAC 7700N enables users to connect to multiple computers or wired-Ethernet devices easily and enjoy blistering LAN transmission for multimedia applications such as interactive gaming, IPTV video streaming and real-time audio.
Billion BIPAC 7700N - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPPoE, AAL5, IPoA, OAM F4, OAM F5
Remote Management Protocol
SNMP 1, SNMP 2
Firewall protection, switching, DMZ port, routing, DHCP support, NAT support, VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, SPI, DoS attack prevention, content filtering, packet filtering, dynamic DNS server, manageable, WDS support, QoS, WPS
ANSI T1.413, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP
15 cm x 11 cm x 2.2 cm
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
SNMP 1, SNMP 2
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.5 Annex M, ITU G.992.3 Annex M
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL
Aerial
Aerial
External detachable
Antenna Qty
2
Gain Level
2 dBi
External power adapter
15 cm
11 cm
2.2 cm
20 - 95% (non-condensing)
