The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
- Cables Direct audio cable - 3 m
- Cable
- Audio cable
- Length
- 3 m
- Connector
- Stereo mini jack - male
- Connector (Second End)
- 2 x RCA - male
- Cable Type
- Audio cable
- Length
- 3 m
- Plated Connector
- Gold
- Connector
- Mini-phone stereo 3.5 mm - male
- 2 x RCA - male
Customer reviews
Write a review for the Cables Direct Stereo Jack to 2 x RCA here!
2.40 fair price. Good for turning tapes and LPs into MP3
Reviewed by david. Review Posted 19/03/2008
You can buy these in small electrical outlets for around the £2.50 mark. Unless you got to some of the major stores to get charged more. I wouldnt have paid postage on it. IE I ordered it with a micro SD card and Sd convertor, HDD & saccnner when there was a no postage special offer if you spend over £99 at dab. I did that on 15/3/2008 it arrived on the 19/3/2008 and so reasonable enough. These cables are good for plugging the phono-out form you HI-FI into the stereo mini-jack microphone socket of you PC sound card (the red one), allowing you to record tapes or vinyl to PC and save it as wav file using free software like Audacity. Then convert this to mp3 using free software such as CDEX (based on the old Winamp). Search for them. MP3 surgeon can be used to cut up your MP3s into individual tracks. Cable does not come with gold connectors, but nobody needs that nonsense anyhow. Imagine, all your old tapes and LPs as MP3 for £2.50, that is good! Recommended!
- Overall
- Ease of use
- Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
