High-density equipment creates an environment where traditional air distribution methods are often not effective. Densely packed enclosures can cause IT equipment to overheat, resulting in downtime. The Rack Air Removal Unit SX captures exhaust heat, returns the warm air to the plenum and eliminates hot spots from the data center. Through automatic fan speed control based upon temperature, the fans will self-adjust for optimal performance. With a unit-mounted LCD display, users can view temperatures at the rack, monitor alarm conditions and adjust unit set points. The integrated network management card allows for remote monitoring and control of the Rack Air Removal Unit SX. This space-saving solution mounts to the back of either the Netshelter SX or VX enclosure, requiring zero U space.
LCD display
Alpha-Numeric Display which displays system parameters and alarms -
Temperature monitoring
Changes in temperature are reported via the user interface or e-mail -
Increased capacity
Higher rate of heat removal allows more equipment to be installed in each rack -
Ducted Exhaust System
Removes hot air from the data center to prevent re-circulation and eliminate air mixing -
Fan guards
A safety measure that provides protection from the fan opening by covering the inlet -
Dual A-B Power Inputs
Draws power from the UPS for power protection with dual feeds for redundancy -
Fault-tolerant fan system
In the event of a fan failure, the remaining fan(s) will continue to operate -
Field replaceable components
Fans and electronics module can be readily replaced without uninstalling the unit -
Adjustable mounting frame
The frame can mount on Netshelter SX or VX enclosures and extends to accommodate 42U, 47U or 48U rack heights
- APC - rack fan kit
- Product Type
- Rack fan kit
- Designed For
- P/N: AP7950B, AR3106SP, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, NBPD0160A, NBWL0355A, NBWL0356A, SMC15002U-BR, SMC1500I2U-BR, SMC1500I-2UC, SMT3000I2U-BR, SMX2000LVNCUS, SMX2000LVUS, SMX3000HV-BR, SMX3000HVTUS, SMX3000LV2U-BR, SMX3000LVUS, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500RMXLA-NC
- Product Type
- Rack fan kit
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC2513, AP5017, AP5602, AP5606, AP5607, AP5616, AP7555, AP7562J, AP7701X298, AP7841, AP7852, AP7854, AP7857, AP7867, AP7894, AP7911, AP7940, AP7941, AP7950, AP7950B, AP7951, AP7952, AP7953, AP7954, AP7957, AP7961, AP7961X364, AP7991, AP92200, AP9290, AP9571, AR2900, AR2901, AR3000, AR3100, AR3100CTO, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100-TU, AR3100W, AR3100X487, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3810, AR3812, AR7007, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, DLA1500RM2U, NBPD0160A, NBPD0171, NBWL0355A, NBWL0356A, SBATTBLK, SC250RM1U, SC250RMI1U, SMC15002U-BR, SMC1500I-2U, SMC1500I2U-BR, SMC1500I-2UC, SMT3000I2U-BR, SMX2000LV, SMX2000LVNC, SMX2000LVNCUS, SMX2000LVUS, SMX2200R2HVNC, SMX3000HV-BR, SMX3000HVT, SMX3000HVTUS, SMX3000LV, SMX3000LV2U-BR, SMX3000LVUS, SRT1000RMXLA, SRT1000RMXLA-NC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500RMXLA, SRT1500RMXLA-NC, SU1400RMXLB3U, SU3000RMJ3U3W, SU3000RMJ3UOS3, SU5000R5TBXFMR, SUA1500R2X138, SUA2200R2X106, SUA2200R2X147, SUA2200R3XLNETPKG, SUA2200RMXL3U, SUA2200RMXLI3U, SUA3000R2IX38, SUA3000R2X180, SUA3000R2X428, SUA3000R3XLNETPKG, SUA3000RMXL3U, SUA3000RMXL3U-BR, SUA750R2X122, SUA750R2X338, SURT10000RMXLT, SURT10000RMXLT-2TF5, SURT3000RMXLI, SURT3000RMXLT, SURT3000RMXLT-1TF5, SURT5000RMXLI, SURT5000RMXLT, SURT5000RMXLT-1TF5, SURT5000XLIX438, SURT6000RMXLT, SURT6000RMXLT-1TF5, SURT7500RMXLI, SURT7500RMXLT, SURT7500RMXLT-1TF5, SURT7500XLJ-2TF4, SURT8000RMXLT, SURT8000RMXLT-1TF5, SURTA1500RMXL, SURTA2000RMXL, SURTA2000RMXL2U, SURTA3000RMXL, SURTD3000RMXLT, SURTD3000RMXLT-1TF5, SURTD5000RMXLT, SURTD5000RMXLT-1TF5, SYH2K6RMJ-TF3
