Pulse Power Supplies - A new brand of PSU that ensures stability and value for money. Excellent value for money doesn't mean corners have been cut - every Pulse PSU comes certified RoHS compliant and with Power Factor Control - giving you a safe and stable foundation to build systems from.
Pulse PSU's come with a superb 12cm fan that offers quiet operation but with proper cooling and airflow - less noise means you're working in a more peaceful environment and the right cooling ensures maximum lifespan of your products.
Supplied with all the appropriate cables Pulse provides maximum compatibility with popular CPU's and mainboards.
Specification
- Product Description: PULSE 500W PSU, 120MM SILENT RED FAN, PFC, 2 X SATA, BLACK CASING, RETAIL BOX
- Wattage: 500W
- Size: ATX 12V
- Input Range: 230Vac, 10A, 50-60Hz
- Connectors: 1 x 240 +4 PIN Main, 1 x CPU 4-PIN 12V, 2 X SATA, 3 x 4 PIN Molex Peripheral, 1 x Floppy Drive Connector
- Additional Features: Power Factor Control (PFC), Silent with better ventilation
- Warranty: 1 Year
