Product
Brand
Best Value 5MTR USB 2.0 A M-F EXT CABLE
Quicklinx: 5CFKWS00 Mfr#: USB2-025
The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
FEATURES:
  • USB 2.0 and 1.1 compliant
  • High speed 480Mbits in sec data transfer speed
  • 4 downstream type A USB ports provided
  • Enables a PC to connect to high speed devices
  • Supports both OHCI and EHCI, data transfer
  • Speed up to 480 Mbps
  • Supports self power mode
  • Supports Plug and Play
  • Connect up to 127 USB devices
Cables Direct USB extension cable - 5 m
USB extension cable
Length
5 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
Grey
USB extension cable
Length
5 m
Grey
Connector
