The exciting new USB-HD3.5SI-1A is a stylish, high quality aluminium Disk Enclosure with totally silent operation. The newly designed Aluminium enclosure acts as a built-in heatsink, effectively reducing heat output of the enclosed Hard Disk to enhance reliability and lifespan.
Fully Plug n' Play for leading Operating Systems including MicrosoftTM Windows and MACTM OS X, the USB-HD3.5SI-1A allows your existing 2.5" SATA or IDE Hard Disk to be fitted quickly and with minimal effort. Enjoy fast data transfer speeds courtesy of the USB2.0 interface and immediate data transfer to and from your PC, Notebook or MAC.
- Stylish and portable aluminium design
- Ideal for your existing 3.5" IDE or SATA interfaced hard disk drives
- Re-use your PC, Server or Mac hard disk and keep your data when you upgrade
- Plug n' Play for popular Operating Systems - no drivers needed
- External PSU supplied
- Backup and restore your data at up to 480Mbps
- Transfer interface USB2.0
- Transfer rata 480Mbps(MAX)
- Support HDD 3.5" IDE or SATA interfaced hard disk
- Work temperature -40? ~ 65?
- Work humidity 8% ~ 90%
- Storage humidity 5% ~ 95%
- Operate system Windows98/SE/ME/2000/XP/VISTA/7/8, Mac OS8.6 or above
- Dynamode USB-HD3.5SI-1 - storage enclosure - ATA - SATA, USB 2.0
- Storage enclosure - external
- Bus Type
- SATA, USB 2.0
- Expansion Bays
- 1 x hot-swap - 3.5"
- Hard Drive Form Factor Compatibility
- 3.5"
- Interface
- ATA
- Supported Devices
- Hard drive
- Max Storage Devices Qty
- 1
- Power Source
- Included AC adapter
- System Requirements
- Linux, Apple MacOS 9.1 or later, Microsoft Windows 98/ME/2000/XP
- 3.5"
- Host Bus
- SATA, USB 2.0
Storage Controller
- Interface
- ATA
- Supported Devices
- Hard drive
- 1
- Bays
- 1 x ATA - 40 PIN IDC
- Connections
- 1 x USB 2.0 , 1 storage - Serial ATA-150 - 7 pin Serial ATA
- Included Accessories
- Stand, screwdriver
- Plug and Play
- Power Source
- Power adapter
- Software Included
- Driver
- OS Required
