Your basket is empty
Best Value 24 Port Cat 6 Punch Down Patch Panel
Quicklinx: 7YLLWS00 Mfr#: UT-8824
Ports: 24 ports
£19.47 ex VAT
£23.36 inc VAT
The UT-8824 is a 24 port 1U rack mountable CAT6 patch panel which is a great solution for network and cable management. The UT-8824 offers a clearly labelled, neat and effective CAT6 pass through panel which is ideal for the heart of any medium sized network.
Specification
  • Meets the TIA/EIA-568-B.2-1 Category 6 Channel Testing Performance requirements.
  • Support T568 A&B wiring & Easy installation.
  • Dual IDC connector can accept 22-26 AWG solid and stranded UTP cables.
  • 24 Port (1U)
  • Compatible with 110 or Krone Tools.
  • Backwards compatible with Category 3, 5 & 5E.
  • 19" rack mountable.
Ports: 24 ports
Brand: Best Value
Price Range Ex VAT: 0 - 50
