BenQ XL2735 Zowie 27" 2560x1440 1ms USB DP HDMI DVI-D LED Gaming
Quicklinx: CNRKWS00 Mfr#: 9H.LFHLB.QBE
XL-series features the premiere monitors for PC e-Sports, fine-tuned to guarantee the smoothest and responsive experience, and the clearest images to arm you for competition.
  • DyAc technology - same 144 Hz, different clarity
    BenQ ZOWIE exclusive technology - "Dynamic Accuracy" maintains remarkable clarity during in-game movement that achieves a smoother experience, enabling players to swiftly capture and hit the targets.
  • Shield - helps you focus on the game
    Shield - reveal the way to be concentrated in games. The adjustable angle and removable design allows Shield to adopt various environments according to preference. Just focus on winning the game.
  • Easily access settings for different scenarios
    Different usage scenarios require different display settings. The S Switch is designed for easy access to settings and switching between saved modes. Whether you are watching, reading, surfing or gaming, switching between the presets and navigating among menus is as simple as 1-2-3. The built-in memory is for saving preferred 3 profiles to go with driverless design.
BenQ ZOWIE XL2735 - XL Series - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
65 kWh
Power Consumption (On mode)
45 W
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
2560 x 1440 at 144 Hz
Pixel Pitch
0.2335 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Input Connectors
2xHDMI, DVI-D, DisplayPort
Display Position Adjustments
63.3 cm x 22.6 cm x 55.9 cm
8.3 kg
Display Type
Energy Class
Class C
65 kWh
45 W
Diagonal Size
27"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2335 mm
Brightness
250 cd/m²
Contrast Ratio
Response Time
1 ms (grey-to-grey)
Backlight Technology
LED backlight
Black eQualizer, Low Blue Light Mode, Flicker Free technology, e-Sports, Shield
63.3 cm x 22.6 cm x 55.9 cm - with stand
8.3 kg
2 x HDMI , DisplayPort , DVI-D (dual link) , Headphones , Microphone , USB upstream , 3 x USB downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
VESA Mounting Interface
100 x 100 mm
Protective cover, S Switch remote control
MTBF
60,000 hour(s)
Security Slot Type
Kensington security slot
30 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 63.3 cm - depth: 6.4 cm - height: 37.4 cm , With stand - width: 63.3 cm - depth: 22.6 cm - height: 55.9 cm - weight: 8.3 kg
