BenQ Zowie's XL-series features the premiere e-Sports monitors for PC competitors, fine-tuned to guarantee the smoothest and responsive experience, and the clearest images to arm you for competition.
- BenQ ZOWIE XL2730 - XL Series - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class B
- Energy Consumption per Year
- 60 kWh
- Power Consumption (On mode)
- 41 W
- USB Hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 2560 x 1440 at 144 Hz
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 90 - 264 V
- Grey, red
- 63.3 cm x 22.6 cm x 55.7 cm
- 7.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV Bauart
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 60 kWh
- Diagonal Size
- 27"
- Built-in Devices
- USB Hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.233 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- HDCP, game mode, Black eQualizer, Low Blue Light Mode, Flicker Free technology, Motion Blur Reduction, K Locker, e-Sports
- Grey, red
- 63.3 cm x 22.6 cm x 55.7 cm - with stand
- 7.5 kg
- 2 x HDMI (HDCP) , VGA (HD-15) , DisplayPort , DVI-D (dual link) , Headphones , Microphone , USB upstream , 3 x USB downstream
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 140 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- S Switch remote control
- TUV Bauart
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 90 - 264 V
- 41 W
- 0.5 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - depth: 6.1 cm - height: 33.5 cm , With stand - width: 63.3 cm - depth: 22.6 cm - height: 55.7 cm - weight: 7.5 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years
- 5 °C
- 40 °C
- 20 - 90%
