Product
BenQ XL2720 Zowie 27" 1920x1080 2ms USB DP HDMI DVI-D LED Gaming
Quicklinx: CNRHWS00 Mfr#: 9H.LEWLB.RBE
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 1ms
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£367.04 ex VAT
£440.44 inc VAT
Enjoy this premiere monitor for PC competitors, fine-tuned to deliver the smooth and responsive experience, and the clear images to arm you for competition.
  • Spot hidden enemies
    Never fall victim to some cowardly camper in a dark corner again. Black eQualizer increases the visibility in dark scenes without overexposing the bright areas.
  • Easily access settings for different scenarios
    Different usage scenarios require different display settings. The S Switch is designed for easy access to settings and switching between saved modes. Whether you are watching, reading, surfing or gaming, switching between the presets and navigating among menus is as simple as 1-2-3.
  • Personalize viewing angles
    The height adjustable stand can be operated with just one finger, so you can easily adjust the height of the monitor to your preferred viewing angle, maximizing your comfort.
  • Game modes for enhanced gaming experience
    Every game has its own optimal settings. The XL monitor is outfitted with several settings. You can easily switch to these game modes with the touch of a hot key.
  • Comfort for long-lasting play
    Flicker-free technology helps reduce eye strain, which can help keep you practicing the extended hours needed to keep you at the top of your game.
  • Minimize visual distractions
    Concentration is a key factor for e-Sports. The XL LCD frame was specially designed to reduce light reflection from the screen, keeping your focus on the game.
BenQ ZOWIE XL Series XL2720 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
50 kWh
Power Consumption (On mode)
34 W
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Input Connectors
2xHDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
64.2 cm x 27.3 cm x 54.8 cm
7.5 kg
Display Type
Energy Class
Class B
50 kWh
34 W
Diagonal Size
27"
Built-in Devices
USB Hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Brightness
300 cd/m²
Contrast Ratio
Response Time
1 ms (grey-to-grey)
Backlight Technology
LED backlight
Game mode, Black eQualizer, Low Blue Light Mode, Flicker Free technology, Motion Blur Reduction, K Locker, e-Sports
64.2 cm x 27.3 cm x 54.8 cm - with stand
7.5 kg
2 x HDMI (HDCP) , VGA (HD-15) , DisplayPort , DVI-D (dual link) , Headphones , USB upstream , 3 x USB downstream
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
Flat Panel Mount Interface
100 x 100 mm
S Switch remote control
Security Slot Type
Kensington security slot
AC 90 - 264 V
50 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 64.2 cm - depth: 26.9 cm - height: 48.5 cm
BenQ XL2720 Zowie 27 Bundle deal on BenQ XL2720 Zowie 27" 1920x1080 2ms USB DP HDMI DVI-D LED Gaming
£462.05
Diagonal Size: 27in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: BenQ
Price Range Ex VAT: 300 - 500
