XL features the premiere monitors for PC e-Sports, fine-tuned to deliver the smooth and responsive experience, and the clear images to arm you for competition.
Native 240 Hz refresh rate - smoothness evolution
Catch every detail of motion and enjoy the fluid gameplay by BenQ Zowie native 240 Hz refresh rate monitor, which ensures a flawless view of fast motion consistently at all time. -
Shield - help you focus on the game
Shield - reveal the way to be concentrated in games. The adjustable angle and removable design allows Shield to adopt various environments, according to preference. Just focus on winning the game. -
Spot hidden enemies
Never fall victim to some cowardly camper in a dark corner again. Black eQualizer increases the visibility in dark scenes without overexposing the bright areas. -
Optimize gaming precision
Color Vibrance gives you the flexibility to get the color performance. With 20 levels of Color Vibrance settings, you can get specific viewing requirements and preferences for all types of gameplay. -
Personalize viewing angles
The height adjustable stand can be operated with just one finger, so you can easily adjust the height of the monitor to your preferred viewing angle, maximizing your comfort.
- BenQ ZOWIE XL2540 - XL Series - LED monitor - Full HD (1080p) - 24.5"
- LED-backlit LCD monitor - 24.5"
- Energy Class
- Class B
- Energy Consumption per Year
- 49 kWh
- Power Consumption (On mode)
- 33 W
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Brightness
- 400 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xHDMI, DVI-D, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 90 - 264 V (47 - 63 Hz)
- Black, red
- 51.543 cm x 22.604 cm x 56.994 cm
- 7.5 kg
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 49 kWh
- Diagonal Size
- 24.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Brightness
- 400 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 24 - 240 Hz
- Horizontal Refresh Rate
- 15 - 160 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Black eQualizer, Low Blue Light Mode, Flicker Free technology, Shield
- Black, red
- 51.543 cm x 22.604 cm x 56.994 cm - with stand
- 7.5 kg
- 2 x HDMI , DisplayPort , DVI-D (dual link) , 2 x USB 3.0 downstream , USB 3.0 upstream , Headphones , Microphone
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 140 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Protective cover, S Switch remote control
- Cables Included
- 1 x DisplayPort cable , 1 x USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 33 W
- Power Consumption (Typical)
- 55 Watt
- 0.5 Watt
- On / Off Switch
- No
- Limited warranty - 2 years - pick-up and return
- 5 °C
- 40 °C
- 20 - 90%
