The next-generation gaming monitor, the XL24303, is a full package of gaming-focused solutions tailored to bring out the best in every gamer. Built with perfect motion, fast gaming, precise control, intuitive experience and gaming eye care, the 24" battle machine is at the peak of design perfection.
Motion Blur Reduction for extra clarity throughout the game
BenQ's Motion Blur Reduction technology further enhances an ultra-smooth, free-of-blur gaming experience, particularly for action-packed FPS games where every millisecond counts. With Motion Blur Reduction, gamers no longer suffer from time and gaming comfort lost to poor vision quality created by motion blur and lagging. Instead, they have everything to gain with more reaction time advantage on their side to achieve ultimately a flawless victory. -
Fast 1ms GTG response time
Fast response time of 1ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display. -
144Hz Gaming Refresh rate with Optimization Management
As the world's leading brand in gaming monitor, BenQ manages to provide more than just the refresh rate feature for different resolutions to reach more levels of optimal refresh rates (100/120/144Hz) with Gaming Refresh rate Optimization Management, which aims to bring users the incomparable gaming performance. With this gamer-driven feature that collaborates with Display Mode and Smart Scaling strengths, BenQ offers a total refresh rate solution for gaming enthusiasts. -
20-Level Color Vibrance Setting to optimize gaming precision
It is absolutely vital that the XL2430T gives you the flexibility you need to get the color performance you seek. This is why BenQ built into the monitor 20 levels of Color Vibrance settings to meet gamers' specific viewing requirements and preferences for all types of gameplay. This unique feature is accessible via On Screen Display (OSD) or Display Pilot for added convenience. -
Adjustment Scale Design for effortless set-up every time
To ensure that gamers can duplicate the exact same monitor set-up with the highest accuracy, efficiency and convenience, BenQ made a few additions to the XL2430T's Adjustment Scale Design. The adjustable height stand is now scaled with 14 height levels trackable by a moving marker. Trackable scales are also added to the screen, which tilts forward and backward to 0°, 10° and 20°, and swivels left and right to a wide range of angles. Every XL2430T can be your personal XL2430T. -
Black eQualizer Dynamic with automatic brightness adjustments
The Black eQualizer Dynamic color engine technology takes visibility optimization to a whole new level with automatic brightness adjustments. The XL2430T is able to detect the input source and automatically fine-tune the amount of brightness enhancement within the range of the brightness level selected by the user. Now, gamers can spot their enemies in critical combat effortlessly and react to any situation quickly without having to lift a finger for manual adjustments. -
Special gaming presets used by the professional
Download special gaming presets used by the professional players so you can see what the pros see. Each mode is fine-tuned so you can leverage these exclusive presets used by pro gamers to your own advantage. They can also be saved on your S Switch for quick access and game play. More presets from professional gamers will be released in the future so you can always stay on top of your game. -
Auto Game Mode Setting for added ease and convenience
The Auto Game Mode enables the XL2430T to detect the genre of the game being played and switch the display setting to the corresponding game mode automatically. It is also designed to make new game mode recommendations for download. This unique feature is accessible through the On Screen Display (OSD) setting as well as the Display Pilot software or the S Switch Arc that has a quick key built in for this mode. -
S Switch Arc with a Rounder Fit for more comfort
The S Switch Arc is an external controller that comes with preset buttons that can be customized with personal display settings for gaming, work or entertainment use. The S Switch Arc not only sports a quick key for the Auto Game Mode but also a rounder look for a more natural and comfortable grip that enables gamers to best navigate between game modes.
- BenQ XL2430T - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 46 kWh
- Power Consumption (On mode)
- 32 W
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.276 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 12000000:1 (dynamic)
- Response Time
- 1 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- 2xHDMI, DVI-D, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (47 - 63 Hz)
- Black / red
- 56.8 cm x 19.9 cm x 52 cm
- 7 kg
- Environmental Standards
- ENERGY STAR Qualified
- TUV Bauart
- 2-year warranty
- Display Type
- Energy Class
- Class B
- 46 kWh
- Diagonal Size
- 24"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 24 - 144 Hz
- Horizontal Refresh Rate
- 15 - 140 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, sharpness, input select, colour temperature, phase
- Carrying handle, HDCP, Auto Brightness Control, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, game mode, Black eQualizer, Smart Scaling, NVIDIA 3D LightBoost technology, integrated cable management, FPS Mode, Low Blue Light Mode, Flicker Free technology, RTS Mode, Motion Blur Reduction, Display Pilot, 72% NTSC colour gamut
- Black / red
- 56.8 cm x 19.9 cm x 52 cm - with stand
- 7 kg
- 2 x HDMI (HDCP) , VGA (HD-15) , DisplayPort , DVI-D (dual link) , Headphone/microphone combo jack , 2 x USB 3.0 downstream , USB 3.0 upstream , Management (USB)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 45
- Rotation Angle
- 90
- Height Adjustment
- 140 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Protective cover, S Switch remote control
- Cables Included
- 1 x USB cable , 1 x DVI cable
- TUV Bauart
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 32 W
- Power Consumption (Typical)
- 23.2 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Drivers & Utilities, Display Pilot
- OS Required
- Microsoft Windows 7, Windows 8, Windows 8.1
- Dimensions & Weight Details
- Without stand - width: 56.8 cm - depth: 6.1 cm - height: 33.5 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years - pick-up and return
- 5 °C
- 40 °C
- 20 - 90%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
