BenQ XL2430 Zowie 24" 1920x1080 2ms HDMI DVI-D LED Gaming Monitor
Quicklinx: CNR0WS00 Mfr#: 9H.LF1LB.QBE
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
Hurry, only 1 left in stock!
£326.26 ex VAT
£391.51 inc VAT
The next-generation gaming monitor, the XL2430T, is a full package of gaming-focused solutions tailored to bring out the best in every gamer. Built with perfect motion, fast gaming, precise control, intuitive experience and gaming eye care, the 24" battle machine is at the peak of design perfection.
  • Motion Blur Reduction for extra clarity throughout the game
    BenQ's Motion Blur Reduction technology further enhances an ultra-smooth, free-of-blur gaming experience, particularly for action-packed FPS games where every millisecond count. With Motion Blur Reduction, gamers no longer suffer from time and gaming comfort lost to poor vision quality created by motion blur and lagging. Instead, they have everything to gain with more reaction time advantage on their side to achieve ultimately a flawless victory.
  • Fast 1 ms GTG response time
    Fast response time of 1 ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display.
  • Gaming Refresh rate Optimization Management (GROM)
    As the world's leading brand in gaming monitor, BenQ manages to provide more than just the refresh rate feature for different resolutions to reach more levels of optimal refresh rates (100/120/144 Hz) with Gaming Refresh rate Optimization Management (GROM), which aims to bring users the incomparable gaming performance. With the gamer-driven GROM that collaborates with Display Mode and Smart Scaling strengths, BenQ offers a total refresh rate solution for gaming enthusiasts.
  • 20-level color vibrance setting to optimize gaming precision
    It is absolutely vital that the XL2430T give you the flexibility you need to get the color performance you seek. This is why BenQ built into the monitor 20 levels of Color Vibrance setting to meet gamers' specific viewing requirements and preferences for all types of gameplay. This unique feature is accessible via On Screen Display (OSD) or Display Pilot for added convenience.
  • Adjustment scale design for effortless set-up every time
    To ensure that gamers can duplicate the exact same monitor set-up with the highest accuracy, efficiency and convenience, BenQ made a few additions to the XL2430T's Adjustment Scale Design. The adjustable height stand is now scaled with 14 height levels trackable by a moving marker. Trackable scales are also added to the screen, which tilts forward and backward to 0°, 10° and 20v, and swivels left and right to a wide range of angles. Every XL2430T can be your personal XL2430T.
  • Black eQualizer Dynamic with Automatic Brightness Adjustments
    The newly improved Black eQualizer Dynamic color engine technology takes visibility optimization to an unseen level with automatic brightness adjustments. The XL2430T is able to detect the input source and automatically fine-tune the amount of brightness enhancement within the range of the brightness level selected by the user. Now, gamers can spot their enemies in critical combat effortlessly and react to any situation quickly without having to lift a finger for manual adjustments.
  • Customize your individual viewing preference
    The Display mode and Smart Scaling features allow you to change the monitor view to suit your preference and to simulate any in-game experience. Using the Display mode function, the monitor can be easily changed between 7 different screen sizes.
  • S Switch Arc with a rounder fit for more comfort
    The S Switch Arc is an external controller that comes with preset buttons that can be customized with personal display settings for gaming, work or entertainment use. The S Switch Arc not only sports a quick key for the Auto Game Mode but also a rounder look for a more natural and comfortable grip that enables gamers to best navigate between game modes.
  • A superior build for a rock-steady gameplay
    Sporting the latest angular, compact base that aligns perfectly parallel to the desk surface and a monitor stand meticulously placed in golden ratio to counter balance the display, the next-generation base stand design offers a high level of stability for the steadiest gameplay - with stringent swivel and shock testing results to prove it. Additionally, the reduced width and depth further shortens the distance between the keyboard and the monitor, bringing you closer than ever to the game.
  • Refined metallic appeal perfected by ergonomic handle design
    The aluminum alloy coated monitor stand sends off a sophisticated yet mysterious metallic appeal that conjures up the majesty of the game. On top of that, it is ergonomically optimized with a widened and thickened top handle that's comfortable to grip, making the monitor much easier to carry from one place to another.
  • Retractable metallic headphone hook adding flexibility and durability
    Placing a retractable headphone hook on the left side of the monitor display conveniently puts your headphones within arm's reach. The material of the headphone hook, which has been upgraded to aluminum alloy, offers extra hardness and strength for improved durability.
  • Low Blue Light as eye safety precautionary measure
    Practice long hours with clear, comfortable vision or compete with top-notch vision condition with BenQ's Low Blue Light. The blue spectrum light, which is produced by regular computer screens, is a critical cause of eye damage, eyestrain, headaches and sleeping disorders. Now with the offering of various adjustable low blue light levels, gamers can better protect their eyes. So there would be no need for yellow tinted eyeglasses for additional eye protection, and gameplay can be clear, comfortable and hassle-free!
  • Gaming-comfort Flicker-free technology
    Developed in collaboration with pro gamers, the XL2430T has been upgraded to eliminate flickering at all brightness levels. This effectively reduces eye fatigue and elevates gaming performance through extreme visual comfort for even the most hardcore gamers enrolling long hours in action. Armed with the Gaming-comfort Flicker-free technology, the BenQ Gaming Monitor is an epic weapon over your ultimate rivals.
Display Type
Energy Class
Class B
Energy Consumption per Year
46 kWh
Power Consumption (On mode)
32 W
Diagonal Size
24"
3D Capable
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Colour Support
16.7 million colours
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
72% NTSC colour gamut, Senseye 3 Technology, game mode, Black eQualizer, Low Blue Light Mode, Flicker Free technology, Motion Blur Reduction, K Locker, e-Sports
Black, red
56.8 cm x 19.9 cm x 52 cm - with stand
7 kg
2 x HDMI , VGA (HD-15) , DisplayPort , DVI-D (dual link) , 3 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Display Position Adjustments
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
VESA Mounting Interface
100 x 100 mm
Protective cover, S Switch remote control
Security Slot Type
Kensington security slot
50 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 56.8 cm - depth: 6.1 cm - height: 33.5 cm , With stand - width: 56.8 cm - depth: 19.9 cm - height: 52 cm - weight: 7 kg
Environmental Standards
ENERGY STAR Certified
BenQ XL2430 Zowie 24 Bundle deal on BenQ XL2430 Zowie 24" 1920x1080 2ms HDMI DVI-D LED Gaming Monitor
£425.43
Diagonal Size: 24in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: BenQ
Price Range Ex VAT: 300 - 500
