BenQ VZ2470H 24" 1920x1080 4ms HDMI LED Monitor
Quicklinx: CNQMWS00 Mfr#: 9H.LDWLB.Q5E
The BenQ VZ2470H monitor with the narrow bezel chic design, delivers rich and exquisite visual performance that please your eyes. A pure expression of broad viewing from inside out.
  • The modern sleek design
    The BenQ V70 series with the narrow bezel chic design, delivers rich and exquisite visual performance that please your eyes. A pure expression of broad viewing from inside out.
  • Ultra-slim design for boundless views and endless sensation
    Visually stunning inside and out, the BenQ V70 series is designed to enhance your viewing experience like never before. Let your eyes feast on the impeccable view enabled by the edge-to-edge (E2E) ultra-slim bezel design and superior image performance.
  • VA panel boasts an ultra-high 3000:1 native contrast ratio
    The display panel is pivotal to the picture quality. The VA panel delivers unsurpassed true black so the image is naturally richer and multidimensional. An ultra-high native contrast ratio of 3000:1brings outstanding definition even from dark shadows to the most detailed images, making viewing vibrant colors and the most discrete details easy on your eyes.
  • Superior response time
    Enjoy high dynamic videos without ghosting or other artifacts with 4ms GTG response time.
  • Flicker-free backlight for visual pleasure
    Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but can certainly feel them. The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Free your eyes from flickers by switching to Flicker-free Monitors and let your eyes do less work.
  • 4 user scenario modes offer unrivaled viewing experience
    Advanced 4 user scenario modes offered through Low Blue Light Plus are tailor-designed to bring the highest image quality and healthiest viewing experience for a wide array of user behavior. The ultimate standard mode effectively reduces hazard blue light while keeping true colors, and the dark room mode allows you to enjoy perfect image quality in dark situations with the added bonus of saving your eyesight.
BenQ VZ2470H - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class B
Energy Consumption per Year
40 kWh
Power Consumption (On mode)
22.8 W
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
White
53.93 cm x 21.18 cm x 41.96 cm
4.9 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
40 kWh
Diagonal Size
23.8"
Panel Type
A-MVA+
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.274 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Low Blue Light Mode, Flicker Free technology, Ultra Slim Design Bezel
White
4.9 kg
VGA , 2 x HDMI , Headphones
Mechanical
Tilt
Tilt Angle
-5/+20
1 x HDMI cable , 1 x VGA cable
Input Voltage
22.8 W
Power Consumption (Typical)
22.8 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Sustainability Information
ENERGY STAR Certified
Limited warranty - 2 years - pick-up and return
5 °C
20 - 90%
