BenQ VW2430H embodies simple living with eco-friendly sophistication while keeping things interesting with its clean, curvy lines, unconventional asymmetric form and a uniquely designed docking accessory that serves as a holder for your mobile phone and cards.
Deep blacks and minimized light leakage
Enjoy the flawless layering and precisely contrasted details in even the darkest images! Free of bright spots with low light leakage, VA panels are designed to deliver naturally deeper blacks with optimum contrast performance. -
5,000:1 native contrast ratio for color depth and definition
An ultra-high native contrast of 5000:1, which is five times of that of general panels, adds astonishing color depth and definition to darkened, complex images with the greatest subtlety and clarity. With a native contrast ratio this high, you can expect an infinite dynamic contrast ratio that far exceeds your expectations. -
True 8-bit color performance
An 8-bit VA panel delivers smoother and more stable color transitions by rendering a total of 16.7 million color shades simultaneously. A 6-bit panel with Advanced Frame Rate Control (ARFC) requires interpolation to display the same number of colors as a true 8-bit panel does. -
178°/178° wide-viewing angles
VA panels bring truly authentic colors and ultra sharp details from left, right, above and below to your eyes with a wide-viewing angle of 178°/178°. Viewing, as you know it, will never be the same. -
True pure white
No printing. No coating. Free from harmful chemicals, the VW2430H is pure in design and refreshing for the modern minds. -
A place for card & phone
An extra accessory inspired from mountains adds a piece of scenery to your desk as well as serves as a card or mobile phone holder. -
A tray for small keepsakes
Store thumbtacks and paperclips using the small tray on the base stand to keep your desk nice and organized. -
The perfect MacBook companion
M-book mode built via BenQ's exclusive Senseye Human Vision technology, which incorporates six proprietary calibration techniques to achieve the best viewing quality in each of its pre-set viewing modes, this special mode enables the VW2430H to faithfully preserve the color quality of a Macbook display so that users can enjoy the view of their Macbook on a bigger screen.
- BenQ VW2430H - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class B
- Energy Consumption per Year
- 45 kWh
- Power Consumption (On mode)
- 31 W
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 20000000:1 (dynamic)
- Response Time
- 4 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, DVI, VGA
- Tilt
- Voltage
- AC 120/230 V
- White
- 56.8 cm x 19.3 cm x 42.9 cm
- 4.5 kg
- Display Type
- Energy Class
- Class B
- 45 kWh
- Diagonal Size
- 24"
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 4 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Colour temperature
- HDCP, Eco-Mode, Advanced Motion Accelerator (AMA) technology, Senseye Human Vision Technology, Senseye 3 Technology
- White
- 4.5 kg
- VGA , DVI , HDMI , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- 31 W
- Power Consumption (Typical)
- 40 Watt
- Power Consumption Stand by
- 0.3 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - width: 56.8 cm - depth: 6.3 cm - height: 33.5 cm
