Featuring a Full HD native resolution, a brightness of 3,200 ANSI lumens and a high contrast ratio of 12,000:1, the TH681+ offers a stunning full-screen presentation with the finest details regardless of the ambient light level.
Premium Full HD 1080p resolution
With the BenQ TH681+, business presentations will never look the same! The TH681+ supports multiple video formats including 480p, 576p, 720p, 1080i and 1080p - giving you the flexibility to present in the latest video formats with Full HD quality. The BenQ TH681+ sets a new standard of video presentation that delivers more detail than traditional 480p projectors. -
Triple Flash
Triple Flash technology is integrated in the DLP chip of Texas Instruments and home video projectors of BenQ are equipped with this feature. It improves 3D viewing perception of movies as 3D movies are currently distributed at 48 frames per second: 24 for the right eye and 24 for the left one. To smoothen the projection even better, the frame rate is tripled from 48 Hz to 144 Hz (48x3) and this is called Triple Flash which gives a better sensation of 3D perception. -
Power saving, eco friendly
Offering lower maintenance cost, uncompromised brightness, exquisite picture quality and optimized lamp life - BenQ's SmartEco technology has perfected what a DLP projector can do in business projector. With this special innovation, you are able to save up to 70% of lamp power consumption and lower maintenance costs through dynamic power saving features while bringing an ultra-vivid picture quality in every meeting room. -
SmartEco mode
The SmartEco Mode, which cleverly adjusts the lamp power to maximize power saving by delivering the best contrast and brightness performance using only as much light as needed. -
0.5 W in standby mode
When inactive, the TH681+ keeps power consumption to a minimum with 0.5 W standby power. This technological advancement in energy saving certainly helps extend the projector lamp life and lower energy costs. -
Auto power off
Automatic power off after the projector is turned on for over 30 minutes without a display source, eliminating unnecessary energy waste and prolonging the life of the projector lamp. -
Upper lamp door for easy lamp access
The upper lamp door is designed for IT managers to replace the projector lamp safely and quickly. Should the projector lamp go out in the middle of the class, it can be replaced without delaying the class. -
Timeless image quality
BenQ DLP projectors are built with enduring enjoyment in mind, ensuring razor-sharp clarity, ultra-readability and true-to-life color for years to come. It uses DLP Technology to reflect pure light from millions of micro mirrors on a DMD chip through an advanced color wheels. Since the mirrors are colorless and protected within a nearly-sealed engine, BenQ DLP Projectors have no aging problems and are virtually immune to image decay, consistently delivering picture excellence time and time again. In fact, after 2,000 hours of intense usage, inserting a new bulb produces image quality comparable to a brand-new projector. DLP Technology also affords a filter-free engine design for carefree confidence in long-lasting image quality and reduced total cost of ownership. BenQ's SmartEco Technology further boosts contrast performance and image quality endurance while saving up to 70% on lamp power consumption. -
Razor-sharp clarity with ultra-readability
Enabling a 96% fill factor, DLP Technology supplies pixel circuitry behind the pixel, thereby eliminating the thick dark bezels around individual pixels, which diminish color and detail. A higher fill factor and less black border translate to noticeably purer, more intense color and smoother image quality. BenQ DLP projectors also feature high contrast ratios for flawless rendering of small text, fine lines, and dark scene details. Blacks are deeper and overall image quality is more focused and clean. Your presentations will be easily readable and highly effective, even from the back row of a well-lit venue. -
Vibrant, true-to-life colors
Even in lit venues, BenQ DLP projectors achieve the optimal balance of brightness and color accuracy, with BrilliantColor Technology additionally boosting true-to-life colors that captivate. BrilliantColor enables up to six-color processing by incorporating the secondary colors Yellow, Cyan, and Magenta along with primary Red, Blue, and Green. From intense hues to elusive mid-tones like aqua blues and light yellows, your every presentation is rendered in pure, living splendor.
- BenQ TH681+ - DLP projector - portable - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 12000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb life cycle
- Up to 4000 hour(s) - normal mode , Up to 6500 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Power
- AC 120/230 V (50/60 Hz)
- 270 Watt
- 31.181 cm x 24.412 cm x 10.47 cm
- 2.6 kg
- 3D Capable
Projector
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 12000:1
- Image Size
- 114.3 cm - 762 cm
- Throw Ratio
- 1.15 - 1.5:1
- Resolution
- Full HD (1920 x 1080) (native) / 1920 x 1200 (resized)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb life cycle
- OSD Languages
- Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
- ecoFACTS, SmartEco Technology, Auto Power Off, 3D Triple Flash technology
Lens
- Lens Aperture
- F/2.59-2.87
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
- Vertical Lens Shift
- 110% / 110%
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, component video, composite video, S-Video
- Video Modes
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x USB - 4 pin mini-USB Type B , 1 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - RCA x 2
- Included Accessories
- Lens cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Voltage Required
- 270 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.181 cm
- 24.412 cm
- 10.47 cm
- 2.6 kg
- Sound Emission
- 33 dBA
- Sound Emission (Economic Mode)
- 28 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
