BenQ SW2700PT 27" 1920x1080 5ms DVI HDMI DisplayPort USB IPS LED Monitor
Quicklinx: BSY9WS00 Mfr#: 9H.LDKLB.QBE
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 5ms
Interfaces: DisplayPort, DVI, HDMI
£640.88 ex VAT
£769.05 inc VAT
Preserve the true colors you captured and make sure the moments are perfect. BenQ SW2700PT photographer monitor with IPS technology and excellent 99% Adobe RGB color space, it gives you a wide color range and spectacular colors display. Keep the moment and never let it fade away.
BenQ PhotoVue SW2700PT - SW Series - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
68 kWh
Power Consumption (On mode)
46 W
USB 3.0 hub, SD card reader
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI, DisplayPort
Display Position Adjustments
65.28 cm x 32.28 cm x 44.52 cm
8.3 kg
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Display Type
Energy Class
Class C
68 kWh
46 W
Diagonal Size
27"
Built-in Devices
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 89 kHz
Video Bandwidth
270 MHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Colour Temperature
9300K, 5000K, 6500K
Controls & Adjustments
Colour temperature
sRGB colour management, HDCP, Senseye 3 Technology, 99% Adobe RGB colour gamut, 14-bit 3D lookup table, Advanced Hyper Viewing Angle (AHVA)
65.28 cm x 32.28 cm x 44.52 cm - with stand
8.3 kg
DVI-D (dual link) , HDMI , DisplayPort , Headphones , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
Tilt Angle
-3.5/+20
Swivel Angle
70
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Detachable hood, controller
1 x DVI cable - DVI-D to DVI-D - 1.8 m , 1 x DisplayPort cable - miniDisplayPort to DisplayPort - 1.8 m , 1 x SuperSpeed USB cable - USB Type A to B - 1.8 m
Security Slot Type
Kensington security slot
AC 90 - 264 V
36.7 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 65.28 cm - depth: 32.28 cm - height: 44.52 cm - weight: 8.3 kg , Without stand - width: 65.28 cm - depth: 21.14 cm - height: 39.67 cm
ENERGY STAR Certified
3-year warranty
5 °C
20 - 90%
BSY9 C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BSY9 C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.18
BSY9 C2G 5m Select High Speed HDMI with Ethernet In Stock £20.65
BSY9 C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
Diagonal Size: 27in
Response Time: 5ms
Interfaces: DVI
Interfaces: HDMI
Brand: BenQ
Price Range Ex VAT: 500 - 750
