BenQ RP84G 84" Touch Screen Display
Quicklinx: CBT6WS00 Mfr#: 9H.F12TC.DE2
Featuring the eye-care technology, BenQ IFP RP840G can reduce harmful effects from blue light emissions. With its Interactive Flat Panel, the driver-free touch-screen functionality is right out of the box on major operating systems and most supported platforms. BenQ IFP RP840G is the innovative display system that fits every classroom's need.
  • Low blue light technology
    The interactive flat panels are built with BenQ's low blue light technology to reduce harmful blue spectrum light emission, which causes eyestrain, eye fatigue and even mascular degeneration. The low blue light technology features the Classroom mode that combats the possible side effects associated with blue light in every usage occasion.
  • Anti-glare glass
    The screen's anti-glare glass reduces reflection, for more legible text and clearer images, helping students avoid eyestrain and facilitating more effective instruction.
  • OSD menu with Touch
    OSD menu with Touch is straight forward to use and allows users to switch video source/volume/brightness at fingertips. This provides you a more intuitive way to use IFP even without the help of the remote controller/button.
  • Multi-platform compatibility
    Compatible with major operating systems from Windows to Mac, Linux and Chrome, the interactive flat panels are built to work seamlessly with a wide range of computing and mobile devices with a simple plug and play.
  • DisplayNote software
    The DisplayNote software is a cross platform solution that facilitates real-time collaboration across multiple computing and smart devices, enabling everyone to stream content and contribute to the presentation. The Wireless Desktop Control feature further allows teachers to mirror and wirelessly control their PC from anywhere in class, freeing them from traditional lecture style teaching.
  • BenQ QCast
    The BenQ QCast software enables seamless wireless streaming and mirroring of all digital contents through a BenQ WiFi dongle, empowering teachers to enrich their lesson plans with a variety of multimedia resources.
  • Build-in EZWrite software
    The EZWrite Software supports annotation function easily. With this build-in whiteboard software or function, educators are able to write and paint directly without any device, like PC/NB.
  • MDA software (LAN only)
    Multiple Display Administrator (MDA) saves time and effort by providing remote management of BenQ Interactive Flat Panel MDA also supports remote shutdowns of equipment not in use, saving significant power costs.
  • Ultra-high-definition resolution
    A 3840x2160 4K2K ultra-high-definition (UHD) resolution offers over 300% more working space than a 1920x1080 FHD does - for the most detailed on-screen viewing quality.
BenQ RP840G 84" LED-backlit LCD display - 4K
LED-backlit LCD flat panel display with touchscreen
Diagonal Class
84"
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
Composite, HDMI
HDMI Ports Qty
4 ports
PC Interface
VGA (HD-15)
LCD Backlight Technology
LED backlight
TV Tuner
No tuner
Picture Enhancements
72% Colour Saturation NTSC
Speaker System
2 speakers
USB
2 ports
Remote control, 2 touch pens, DisplayNote card
Voltage
550 Watt
Power Consumption Stand by
0.5 Watt
197.82 cm x 9.5 cm x 118.6 cm
116 kg
3-year warranty
550 Watt
Diagonal Class
84"
Combined With
Touchscreen
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
Composite, HDMI
HDMI Ports Qty
4 ports
PC Interface
VGA (HD-15)
Modes
Landscape mode
Protection
Tempered glass protection
197.82 cm
9.5 cm
118.6 cm
116 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
LED backlight
Coating
Anti-glare
Image Contrast Ratio
1600:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Touchpoints Qty
10
Response Time
8 ms
Display Menu Language
English, French, Spanish
Backlight Life
50,000 hour(s)
Eye Care, infrared multitouch technology, Low Blue Light Technology, EZWrite Software, Multiple Display Administrator (MDA)
Stands & Mounts
Stand
Optional
Flat Panel Mount Interface
600 x 600 mm
Media Player
USB Port
USB Ports Qty
2
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Output Power / Total
20 Watt
Speakers
2 x main channel speaker - 10 Watt
Connector Type
Composite video input , 4 x HDMI input , 3 x VGA input , VGA output , Serial input , LAN , 2 x USB , Audio input , Headphones , 3 x audio line-in , Audio output
USB cable - 10 m , VGA cable - 5 m , Audio cable - 5 m
Power supply
Input Voltage
0.5 Watt
Power Consumption Sleep
0.5 Watt
Limited warranty - 3 years
Width (Shipping)
217 cm
Depth (Shipping)
32 cm
Height (Shipping)
137 cm
Weight (Shipping)
146 kg
