The BenQ RP series touch interactive flat panels provide educators access to tools and resources never before available. With improved access to interactive online resources, teachers can now explain and illustrate subjects in ways students can more easily understand. This increases students' interest in the subjects at hand and improves the classroom experience.
HD resolution for remarkable image clarity
A visually HD image resolution does much more than just capture students' attention. It also provides a high level of viewing clarity for subjects such as biology, chemistry and fine arts that require visual demonstrations of detail-oriented images. -
Low Blue Light
Studies show that blue light originating from digital displays such as smartphones and tablets, as well as from fluorescent lamps, can have adverse effects on eyes and the human body. This blue light may cause eye discomfort which can lead to eyestrain, lack of focus and even mental fatigue. BenQ displays feature a Low Blue Light mode to effectively eliminate blue light emissions, enabling teachers' eyes to remain focused and refreshed, even after prolonged use. -
ZeroFlicker for refreshed eyes
The image on conventional displays flickers at up to 200 times per second to achieve the desired brightness level, creating a level of visual noise that your eyes cannot see but can certainly feel. This visual noise can cause eyestrain, eye fatigue and discomfort. BenQ displays use ZeroFlicker technology, an exclusive direct lighting method that delivers steady, smooth lighting to keep teachers' and students' eyes comfortable and refreshed, even after long hours of use. -
Anti-glare tempered glass with bacteria resistant coating
Screen glare shining in students' eyes can lead to difficulty reading content, which can lead to lack of attention or focus. This can become very uncomfortable and distracting for teachers and students alike. BenQ RP series displays use strong, durable, high-quality anti-glare tempered glass to minimize reflections and produce easier-to-read text with clearer images on the screen, which helps students absorb more of the class material being presented. The glass also features a bacteria-resistant layer that helps sanitize the screen surface. -
Instant touch interactive functionality
Conventional displays can require complicated computer driver installations before enabling touch functionality. BenQ RP series displays feature driver-free touch interactivity, enabling drivers to be automatically loaded in the background with no complications and no hassles. Simply connect the computer to the display's touch USB port and you are ready to deliver a touch-interactive lesson.
- BenQ RP653 65" LED-backlit LCD display - Full HD - for interactive communication
- Product Type
- LED-backlit LCD flat panel display with touchscreen
- Diagonal Class
- 65"
- Commercial Use
- Yes - interactive
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 4 ports
- Connectivity
- LAN
- PC Interface
- VGA (HD-15)
- LCD Backlight Technology
- Direct-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Speaker System
- 2 speakers
- USB
- 4 ports
- Included Accessories
- Remote control, 2 touch pens
- Voltage
- AC 120/230 V (50/60 Hz)
- Energy Class
- Class B
- Power Consumption (On mode)
- 182 W
- Energy Consumption per Year
- 265 kWh
- 3-year warranty
- Product Type
- Energy Class
- Class B
- 182 W
- 265 kWh
- Diagonal Class
- 65"
- Commercial Use
- Yes - interactive
- Combined With
- Touchscreen
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Sensors
- NFC sensor
- Video Interface
- Composite, HDMI
- HDMI Ports Qty
- 4 ports
- PC Interface
- VGA (HD-15)
Display
- Resolution
- 1920 x 1080
- Display Format
- 1080p
- 16:9
- Direct-lit LED
- Coating
- Anti-glare
- Image Contrast Ratio
- 1400:1
- Brightness
- 360 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Touchpoints Qty
- 20
- Response Time
- 6 ms
- Backlight Life
- 30,000 hour(s)
- Infrared multitouch technology, Low Blue Light Technology, EZWrite Software, Flicker free technology
Stands & Mounts
- Flat Panel Mount Interface
- 600 x 400 mm
Media Player
- USB Port
- USB Ports Qty
- 4
- Operating System
- Android OS 4.2.1
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- Connect & Share
- Mobile High-Definition Link (MHL)
- Connector Type
- 3 x VGA input , LAN , 4 x HDMI input , Composite video/audio input , 3 x audio line-in , Serial , USB 3.0 , USB , 3 x USB 2.0 , Headphones
- 2 touch pens
- Power Device
- Power supply
- Input Voltage
- On / Off Switch
- Limited warranty - 3 years - on-site
