Your basket is empty
BenQ RL2460HT 24" 1920x1080 1ms DVI HDMI LED Monitor with Speakers
Quicklinx: BSXWWS00 Mfr#: 9H.LC6LB.QBE
The RL2460 is the best monitor for high-speed PC and console gaming. It is built to handle the raw intensity of the competition in every way. A gaming feature, fighting mode, was co-developed with fighting game legend, Justin "JWong" Wong of Evil Geniuses. It enables gamers to highlight battle characters with special colors. To ensure uncompromised streaming, an HDMI output is available to eliminate input lag. The RL2460HT delivers total victory and gameplay satisfaction.
BenQ RL2460HT - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, VGA
Display Position Adjustments
Height, swivel, tilt
57.9 cm x 21.3 cm x 50.2 cm
5.2 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 6.0
Display Type
Energy Class
Class B
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Mute, volume, brightness, contrast, H/V position, sharpness, saturation, gamma correction, input select, graphic / text mode, colour temperature, phase, clock, focus, black level, hue, aspect control, blue reduction
OSD Languages
Hungarian, Czech, Chinese (traditional), English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Romanian, Japanese, Serbo-Croatian
HDCP, 72% colour gamut, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, game mode, Black eQualizer, FPS Mode, Low Blue Light Mode, Display Pilot
5.2 kg
Audio
Speakers
Output Power / Channel
2 Watt
DVI-D (dual link) , 2 x HDMI , VGA (HD-15) , Headphones (mini-jack) , Audio line-in (mini-jack)
Mechanical
Tilt Angle
-5/+15
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
Flat Panel Mount Interface
100 x 100 mm
K-lock security slot, VESA interface support, Flicker-free technology
1 x DVI cable , 1 x VGA cable , 1 x power cable
TCO Displays 6.0
Power Supply
Internal
AC 90 - 264 V
27 Watt
Power Consumption Stand by
0.5 Watt
ENERGY STAR Certified
BSXW C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BSXW C2G 0.5m Select High Speed HDMI with Ethernet In Stock £5.79
BSXW C2G 5m Select High Speed HDMI with Ethernet In Stock £15.65
BSXW C2G 10m Select High Speed HDMI with Ethernet In Stock £30.41
BSXW C2G 15m Select High Speed HDMI with Ethernet In Stock £41.19
BSXW C2G Pro HDMI to VGA Converter In Stock £46.73
BSXW C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
