BenQ RL2455HM 24" 1920x1080 1ms HDMI DVI VGA LED Monitor with speakers
Quicklinx: 9SCHWS00 Mfr#: RL2455HM
The RL2455HM is a professional gaming monitor suited for RTS game play. This 24" W LED monitor is packed with the features: the black eQualizer, height adjustment Stand, RTS mode, display mode, smart scaling, 1 ms GTG, HDMI and 12M: 1 dynamic contrast ratio. Poor visibility in dark scenes can cost even the most skillful gamers their game. The black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
  • Exclusive RTS mode ensures you would play like a pro
    Every feature and function of the RL2455HM was meticulously through out to provide RTS gamers with vital visibility and command to achieve peak performance. This out-of- the-box preset automatically fine-tunes your monitor accordingly for optimum RTS gaming, allowing you to see your enemies more visibly among the distractions and darkened areas. Built to give you the competitive edge, the exclusive RTS Mode will be your ultimate secret weapon. The exclusive preset RTS Mode will be your ultimate secret weapon.
  • Customize your individual viewing preference
    The display mode and smart scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Or take advantage of the smart scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
  • Fast 1 ms GTG response time
    Fast response time of 1 ms GTG means speed without the smear. Fast-moving action and dramatic transitions will be rendered smoothly - without smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display.
  • ENERGY STAR qualified
    The RL2455HM complies with the requirement of ENERGY STAR program for computer monitors. Now you can enjoy saving energy and money as well as keeping the Earth looking great!
BenQ RL2455HM - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey), 5 ms (typical)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Swivel, tilt
Voltage
AC 120/230 V
Black / red
57.9 cm x 18.9 cm x 43.5 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class B
39 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Advanced Motion Accelerator (AMA) technology, Senseye 3 Technology, Black eQualizer, Smart Scaling
Black / red
57.9 cm x 18.9 cm x 43.5 cm - with stand
4.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D (dual link) , 2 x HDMI , VGA , Headphones , Audio line-in
Mechanical
Swivel, tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), wall mountable
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
AC 120/230 V
27 W
Power Consumption (Typical)
27 Watt
Power Consumption Stand by
0.5 Watt
On / Off Switch
No
Microsoft Windows 7, Windows 8
Dimensions & Weight Details
Without stand - width: 57.9 cm - depth: 6.3 cm - height: 35 cm , With stand - width: 57.9 cm - depth: 18.9 cm - height: 43.5 cm - weight: 4.1 kg
Sustainability Information
ENERGY STAR Certified
