BenQ RL2455 Zowie 24" 1920x1080 1ms DVI-D HDMI LED Gaming Monitor
Quicklinx: CNQWWS00 Mfr#: 9H.LF4LB.DBE
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DVI, HDMI, VGA (HD-15)
£147.11 ex VAT
£176.53 inc VAT
The RL2455HM is a professional gaming monitor suited for console game play. This 24"W LED monitor is packed with the latest features: the Black eQualizer, Display Mode, Smart Scaling, 1ms GTG, HDMI and 12M:1 dynamic contrast ratio.
  • Gaming-comfort Flicker-free technology
    Co-developed by pro gamers, the RL2245HM is upgraded to eliminate flickering at all brightness levels, effectively reducing eye fatigue herewith providing extreme comfort for even the most hardcore gamers after long hours of play time. The gaming focus Flicker-free Technology makes BenQ Gaming Monitor an epic weapon against your opponents!
  • The Black eQualizer gives you total visibility
    Poor visibility in dark scenes can cost even the most skillful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
  • Fast 1ms GTG response time
    Fast response time of 1ms GTG means speed without the smear. Fast-moving action and dramatic transitions will be rendered smoothly - without smearing or ghosting. Control your gaming destiny and don't leave it in the hands of slow display.
BenQ ZOWIE RL2455 - RL Series - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xHDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Black, red
57.9 cm x 18.9 cm x 43.5 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified
TUV GS, ISO 9241-307, TCO Displays 5.2
Display Type
Energy Class
Class B
39 kWh
27 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
HDCP, 72% NTSC colour gamut, Senseye 3 Technology, Black eQualizer, Smart Scaling, Low Blue Light Mode, Flicker Free technology
Black, red
57.9 cm x 18.9 cm x 43.5 cm - with stand
4.1 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
2 x HDMI , VGA (HD-15) , DVI-D (dual link) (HDCP) , Microphone , Headphones
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
AC 90 - 264 V
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 57.9 cm - depth: 6.3 cm - height: 35 cm , With stand - width: 57.9 cm - depth: 18.9 cm - height: 43.5 cm - weight: 7.5 kg
ENERGY STAR Certified
5 °C
20 - 90%
BenQ RL2455 Zowie 24 Bundle deal on BenQ RL2455 Zowie 24" 1920x1080 1ms DVI-D HDMI LED Gaming Monitor
£238.65
Diagonal Size: 24in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: BenQ
Price Range Ex VAT: 100 - 150
