Extended lamp life
Enjoy a significant extension in your projector's usability with a lamp life cycle of up to 3500 hours, extending to 5000 hours in Economic Mode. This feature ensures your presentations and media can shine for longer without the need for frequent replacements, making it a cost-effective solution for both personal and professional use. -
Seamless compatibility
Designed specifically for PC use, this projector lamp integrates smoothly with your existing setup. Its compatibility ensures a hassle-free installation process, allowing you to get back to your presentations and screenings without unnecessary delays.
- BenQ projector lamp
- Product Type
- Projector lamp
- Bulb life cycle
- 3500 hour(s) (standard mode) / 5000 hour(s) (economic mode)
- Designed For
- BenQ MX662, MX720
- Product Type
- Projector lamp
Lamp
- Life Cycle
- Designed For
- BenQ MX662, MX720
