BenQ PD3200Q 32" 2560x1440 4ms DVI HDMI USB 3.0 DisplayPort LED AMVA Monitor with Speakers
Quicklinx: D0M1WS00 Mfr#: 9H.LFALA.TBE
Diagonal Size: 32in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, Mini DisplayPort
Hurry, only 3 left in stock!
£361.26 ex VAT
£433.51 inc VAT
Designed to meet the rising demands for large-sized viewing and stunning definition, the PD3200Q boasts a 32"W 2K display built with BenQ's VA panel technology to provide higher contrast and deeper blacks.
BenQ PD3200Q - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class A
Energy Consumption per Year
57 kWh
Power Consumption (On mode)
39 W
KVM Switch, USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.276 mm
Brightness
300 cd/m²
Contrast Ratio
3000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DVI-D, DisplayPort, Mini DisplayPort
Display Position Adjustments
Height, pivot (rotation), tilt
74 cm x 21.3 cm x 49 cm
12.5 kg
Environmental Standards
ENERGY STAR Qualified
TCO Displays 7.0
3-year warranty
Display Type
Energy Class
Class A
57 kWh
39 W
Diagonal Size
32"
Built-in Devices
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.276 mm
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Eco-Mode, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, CAD/CAM Mode, Dual View, animation mode, OSD controller
74 cm x 21.3 cm x 49 cm - with stand
12.5 kg
Audio
Speakers - stereo
Output Power / Channel
5 Watt
DVI-D , DisplayPort , Headphones , Audio line-in , 4 x USB 3.0 , HDMI
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x SuperSpeed USB cable
TCO Displays 7.0
Security Slot Type
Kensington security slot
AC 90 - 264 V (47 - 63 Hz)
Power Consumption Sleep
0.5 Watt
On / Off Switch
Apple MacOS, Windows 8 / 10
Dimensions & Weight Details
With stand - width: 74 cm - depth: 21.3 cm - height: 49 cm - weight: 12.5 kg , Without stand - width: 74 cm - depth: 6.6 cm - height: 43.6 cm
ENERGY STAR Certified
Limited warranty - 3 years
5 °C
20 - 90%
BenQ PD3200Q 32 Bundle deal on BenQ PD3200Q 32" 2560x1440 4ms DVI HDMI USB 3.0 DisplayPort LED AMVA Monitor with Speakers
£461.02
Diagonal Size: 32in
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: Mini DisplayPort
Brand: BenQ
Price Range Ex VAT: 300 - 500
