BenQ PD2710QC 27" 2560x1440 5ms DVI HDMI USB DisplayPort LED IPS Monitor with Speakers
Quicklinx: D0LZWS00 Mfr#: 9H.LG9LB.QBE
Diagonal Size: 24.5in
Max Resolution: 1920 x 1080
Response Time: 1ms
Interfaces: DisplayPort, DVI, HDMI
20 in stock
£420.31 ex VAT
£504.37 inc VAT
BenQ Designer Monitor PD2710QC is a visually stunning 27" 2K QHD monitor showcasing as BenQ’s first USB Type-C™ monitor. Dock a notebook to the external display’s built-in USB-C™ Docking Station, easily tapping into a range of connectivity options without having the inconvenience of cables and a separate docking station.With 100% sRGB color space coverage, IPS screen technology and an impressive range of modes, you can craft every detail until it leads to brilliant work.
Enjoy more room for incredible creations.
  • DyAc technology - same refresh rate, different clarity
    BenQ ZOWIE exclusive technology Dynamic Accuracy maintains remarkable clarity during in-game movement that achieves a smoother experience, enabling players to swiftly capture and hit the targets.
  • Native 240 Hz refresh rate - smoothness evolution
    Catch every detail of motion and enjoy fluid gameplay by BenQ ZOWIE native 240 Hz refresh rate monitor, which ensures a flawless view of fast-motion consistently at all time.
  • Shield - help you focus on the game
    Shield - reveal the way to be concentrated in games. The adjustable angle and removable design allows Shield to adopt various environments according to preference. Just focus on winning the game.
  • Spot hidden enemies
    Never fall victim to some cowardly camper in a dark corner again. Black eQualizer increases the visibility in dark scenes without overexposing the bright areas.
  • Optimize gaming precision
    Color Vibrance gives you the flexibility to get the color performance. With 20 levels of Color Vibrance settings, you can get specific viewing requirements and preferences for all types of gameplay.
  • Personalize viewing angles
    The height adjustable stand can be operated with just one finger so you can easily adjust the height of the monitor to your preferred viewing angle, maximizing your comfort.
  • Easily access settings for different scenarios
    To customize the XL with different usage scenarios, the S-Switch is designed for easy access to monitor menu, switch between saved modes, and quick change between connected devices. To go your preferred display settings with selected models, S-Switch allows you to save and transfer 3 profiles with driverless design within the same model.
  • Minimize visual distractions
    Concentration is a key factor for e-Sports. The XL-series LCD frame was specially designed to reduce light reflection from the screen, keeping your focus on the game.
BenQ ZOWIE XL2546 - XL Series - LED monitor - Full HD (1080p) - 24.5"
LED-backlit LCD monitor - 24.5"
Energy Class
Class A+
Energy Consumption per Year
26 kWh
Power Consumption (On mode)
18 W
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 240 Hz, HDMI: 240 Hz)
Pixel Pitch
0.28 mm
Brightness
320 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Input Connectors
2xHDMI, DVI-D, DisplayPort
Display Position Adjustments
56.994 cm x 22.604 cm x 44.575 cm
7.5 kg
Display Type
Energy Class
Class A+
26 kWh
18 W
Diagonal Size
24.5"
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.28 mm
Brightness
320 cd/m²
Contrast Ratio
Response Time
1 ms (grey-to-grey)
Backlight Technology
LED backlight
Black eQualizer, Low Blue Light Mode, Shield, Color Vibrance, Dynamic Accuracy
56.994 cm x 22.604 cm x 44.575 cm - with stand
7.5 kg
2 x HDMI , DisplayPort , DVI-D (dual link) , 3 x USB 3.0 downstream , USB 3.0 upstream , Headphones , Microphone
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
140 mm
VESA Mounting Interface
100 x 100 mm
S Switch remote control
Security Slot Type
Kensington security slot
AC 120/230 V
55 Watt
On / Off Switch
No
BenQ PD2710QC 27 Bundle deal on BenQ PD2710QC 27" 2560x1440 5ms DVI HDMI USB DisplayPort LED IPS Monitor with Speakers
£519.48
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Brand: BenQ
Price Range Ex VAT: 300 - 500
