BenQ PD2700Q 27" 2560x1440 4ms HDMI LED Monitor
Quicklinx: CNRTWS00 Mfr#: 9H.LF7LA.TBE
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Mini DisplayPort
More than 50 in stock
£301.99 ex VAT
£362.38 inc VAT
Get pumped up with richer graphics brought by 10-bits of color depth, Rec.709 and standard RGB color space (sRGB), and 2560x1440 resolution. Creatives and designers can now enjoy a smoother work flow with BenQ's PD2700Q monitor, equipped with three display modes (Darkroom, CAD/CAM, and Animation) that accentuate the details of images, making it easier for editing, creating, and visualizing.
  • 2K QHD monitor
    Get pumped up with crisp, gorgeous graphics brought by 2K image resolution
  • 10-bit, 100% sRGB and Rec.709 optimal color precision
    With 10-bits of color depth, Rec.709 and standard RGB color space(sRGB), you’ll have more than 1 billion of colors to work with astonishing precision.
  • Wide viewing Angle with IPS Technology
    PD2700Q is equipped with IPS technology offering a wider viewing angle(178° in both horizontal and vertical planes)to users with exceptional clarity and vivid image quality in all angles.
  • Animation mode
    Animation mode enhances details in dark shadows so you can fine-tune creations effortlessly, while areas that do not require this function remain unaltered.
  • 10-level animation mode Adjustment
    Adjustable animation mode offers 10 levels of display brightness for a clear working plane in any ambient light environment.
BenQ DesignVue PD2700Q - PD Series - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class C
Energy Consumption per Year
63 kWh
Power Consumption (On mode)
43 W
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
12 ms (tr - tf); 4 ms (gray-to-gray)
Colour Support
1.07 billion colours
Input Connectors
HDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments
Pivot (rotation), swivel, tilt
64.1 cm x 23.965 cm x 54.732 cm
6.9 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class C
63 kWh
43 W
Diagonal Size
27"
Built-in Devices
USB 2.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
2560 x 1440
Pixel Pitch
0.2331 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 89 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Advanced Motion Accelerator (AMA) technology, 100% sRGB colour gamut, Low Blue Light Mode, Flicker Free technology, CAD/CAM Mode, Display Pilot, K Locker, Colour Temperature Selection
64.1 cm x 23.965 cm x 54.732 cm - with stand
6.9 kg
Audio
Speakers - stereo
Output Power / Channel
1 Watt
USB 2.0 upstream , 2 x USB 2.0 downstream , HDMI , DisplayPort , Headphones , Mini DisplayPort
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
VESA Mounting Interface
1 x HDMI cable - 1.5 m , 1 x Mini DisplayPort-DisplayPort cable - 1.5 m , 1 x USB cable - 1.5 m
MTBF
60,000 hour(s)
AC 120/230 V
32 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 64.1 cm - depth: 23.965 cm - height: 54.732 cm - weight: 6.9 kg , With stand - width: 64.1 cm - depth: 23.965 cm - height: 41.732 cm - weight: 6.9 kg , Without stand - width: 64.1 cm - depth: 5.65 cm - height: 37.95 cm
ENERGY STAR Certified
BenQ PD2700Q 27 Bundle deal on BenQ PD2700Q 27" 2560x1440 4ms HDMI LED Monitor
£401.16
Diagonal Size: 27in
Response Time: 4ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Brand: BenQ
Price Range Ex VAT: 300 - 500
