BenQ PD2500Q 25" 2560x1440 4ms HMDI DisplayPort LED IPS Monitor with Speakers
Quicklinx: D0LWWS00 Mfr#: 9H.LG8LA.TSE
Diagonal Size: 25in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Mini DisplayPort
More than 50 in stock
£277.77 ex VAT
£333.32 inc VAT
BenQ Designer monitor PD2500Q is a visually spectacular 25" 2K QHD (2560 x 1440) high-resolution display, that showcases every intricate detail in your work. Professionally factory-calibrated for amazing color accuracy and sRGB and Rec. 709 color space support, PD2500Q's pristine IPS panel produces exacting color accuracy for the true and representative view of original content. Crafted in a gorgeous edge-to-edge ultra-slim bezel, PD2500Q provides a seamlessly expansive creative space, when dual monitors are used side by side.
  • 2K QHD (2560 x 1440) high resolution
    Bring out the fine details in your designs with superb clarity and depth of images.
  • Amazing color accuracy
    Individually factory-calibrated to sRGB and Rec. 709 standards and Technicolor Color certified for precise color quality.
  • Specialized designer modes
    Darkroom, CAD/CAM, and Animation modes customize display settings to enhance precision and productivity.
  • Universal connectivity
    Switch conveniently between multiple PC or mobile devices with universal HDMI, DisplayPort, Mini DisplayPort, USB 3.1 connectivity.
  • Edge-to-edge ultra-slim bezel design
    Maximize your workspace with minimal footprint, ideal for dual-monitor usage via daisy-chain technology DP out (MST).
BenQ DesignVue PD2500Q - PD Series - LED monitor - 25"
LED-backlit LCD monitor - 25"
Energy Class
Class B
Energy Consumption per Year
41 kWh
Power Consumption (On mode)
28 W
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440
Pixel Pitch
0.216 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
Display Position Adjustments
Grey
57.02 cm x 23.965 cm x 40.2 cm
7.2 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
3-year warranty
Display Type
Energy Class
Class B
41 kWh
28 W
Diagonal Size
25"
Built-in Devices
USB 3.1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440
Pixel Pitch
0.216 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
24 - 76 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), 100% sRGB colour gamut, Flicker Free technology, CAD/CAM Mode, Ultra-Flexible Height Adjustment System (HAS), animation mode, Bright Intelligence (B.I.)
Grey
57.02 cm x 23.965 cm x 40.2 cm - with stand
7.2 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
USB 3.1 upstream , 4 x USB 3.1 downstream , DisplayPort output (MST) , DisplayPort , Mini DisplayPort , HDMI (HDCP) , Headphones
Mechanical
Tilt Angle
-5/+20
Swivel Angle
90
Rotation Angle
90
Height Adjustment
130 mm
1 x HDMI cable - 1.5 m , 1 x Mini DisplayPort-DisplayPort cable - 1.8 m , 1 x USB cable - 1.5 m
MTBF
60,000 hour(s)
Security Slot Type
Kensington security slot
AC 120/230 V
62 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
Apple MacOS, Microsoft Windows 7 / 8 / 10
Dimensions & Weight Details
With stand - width: 57.02 cm - depth: 23.965 cm - height: 40.2 cm - weight: 7.2 kg , Without stand - width: 57.02 cm - depth: 5.879 cm - height: 35.951 cm
ENERGY STAR Certified
TCO Certified
Limited warranty - replacement - 3 years - on-site
5 °C
20 - 90% (non-condensing)
BenQ PD2500Q 25 Bundle deal on BenQ PD2500Q 25" 2560x1440 4ms HMDI DisplayPort LED IPS Monitor with Speakers
£376.94
Diagonal Size: 25in
Response Time: 4ms
Interfaces: HDMI
Interfaces: Mini DisplayPort
Brand: BenQ
Price Range Ex VAT: 150 - 300
