A wide array of connectivity options plus PointDraw 3.0 and QDraw3 interactive features make the MX822ST a complete classroom projector solution. An ultra short-throw ratio, 13000:1 ultra-sharp contrast ratio, 3500 ANSI lumen brightness and long lamp life ensure vibrant, reliable visual performance time and again.
World-Leading SmartEco technology for a greener environment
As the first DLP brand to incorporate Philips' ImageCare technology into its projector lamp system, BenQ has taken a further leap, developing its own SmartEco technology to perfect what DLP can do for energy saving in classroom. Built with this invention, the MX822ST brings together uncompromised brightness, exquisite picture quality and optimized lamp life through innovative features. -
Eco blank mode
The Eco blank mode allows teachers to blank the projection screen whenever they need to direct their students' focus back on them - or simply when the projector is not in use. When activated, this special feature dims the lamp power automatically, lowering the total power consumption by 70%. -
No source detected mode
The automatic switch to Eco blank mode after the projector is turned on for over three minutes without a display source, eliminating unnecessary energy waste and prolonging the life of the projector lamp. -
Ultra-high contrast ratio
An ultra-high contrast ratio projects sharp images, even for high brightness projectors. Get better contrast and blacker blacks with a 13000:1 contrast ratio. -
Generation PointDraw technology now with the multi-device collaboration mode
BenQ promotes classroom collaboration as well as teacher-student and student-student interaction by facilitating a diverse learning environment that fosters all learners. Its latest creation, the PointDraw technology, takes teaching and learning to a new level with additional support for multi-device collaboration. With simultaneous teacher-student interaction, students can take turn making their contribution to the lesson under the teacher's complete guidance and control. -
Blu-ray Full HD 3D supported
BenQ MX822ST is built with latest DLP technology to support 3D functionality, allowing schools to bring an immersive learning experience to their students with a simple preparation of 3D glasses and 3D content from your Blu-ray player. -
3D capability improvement
Research has shown a 46% increase in student engagement and a 34% increase in test scores with the use of DLP 3D projection. The MX822ST supports HDMI, designed to maximize your audiovisual enjoyment with the capacity to pass two simultaneous 1080p signals with one connection. -
Zero disruptions
Say goodbye to the shadows that often interrupt your presentation. With a projection distance this close, you and your audience can move freely without worrying about obstructions between the projector and the screen! -
LAN Control with Crestron and PJ-Link
LAN Control is designed to help IT managers perform day-to-day projector maintenance and repair tasks efficiently and effectively - offering them full access and control over every projector directly from their workstations. The MX822ST offers seamless support for the Crestron and PJ-Link LAN Control system. -
LAN display
LAN display offers a cost-effective solution for projector implementation management using a single LAN cable to control and display. This feature also offers simultaneous 4-1 or partial projection display option for better content management for discussions, presentations, training and classroom teaching. -
ecoFACTS label
ecoFACTS can tell you how eco-friendly BenQ products are! Development of eco-friendly products, BenQ doesn't just want to comply with green regulations passively, but also to actively develop eco-friendly products! ecoFACTS declares BenQ's greatest efforts on the replacement of hazardous substances, material selection, packaging design, energy-saving design and other aspects of the products.
- BenQ MX822ST - DLP projector - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 3500 ANSI lumens
- Contrast Ratio
- 13000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 310 Watt
- Bulb life cycle
- Up to 2500 hour(s) - normal mode , Up to 3000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 370 Watt
- 32.95 cm x 24.85 cm x 13 cm
- 3.9 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3500 ANSI lumens
- Contrast Ratio
- 13000:1
- Image Size
- 139.7 cm - 762 cm
- Throw Ratio
- 0.626:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- 310 Watt
- Bulb life cycle
- OSD Languages
- Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
- sRGB colour profile, PJlink, ecoFACTS, SmartEco Technology, Eco Blank, QDraw3
Lens
- Lens Aperture
- F/2.8
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 20 Watt
- Speakers
- 1 x mixed channel
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x S-video input - 4 pin mini-DIN , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 2 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x microphone input - mini-phone stereo 3.5 mm , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x network - RJ-45 (management) , 1 x HDMI - 19 pin HDMI Type A , 1 x USB - mini-USB Type B
- Included Accessories
- Lens cover, remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Voltage Required
- 370 Watt
- Power Consumption Stand by
- 0.5 Watt
- 32.95 cm
- 24.85 cm
- 13 cm
- 3.9 kg
- Sound Emission
- 36 dB
- Sound Emission (Economic Mode)
- 34 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
