A wide array of connectivity options plus PointWrite and QWrite interactive features make the MX819ST a complete classroom projector solution. An 0.61 short-throw ratio, 13000:1 sharp contrast ratio, 3000 ANSI lumen brightness and long lamp life ensure vibrant, reliable visual performance time and again.
World-leading SmartEco technology for a greener environment
As the first DLP brand to incorporate Philips' ImageCare technology into its projector lamp system, BenQ has taken a further leap, developing its own SmartEco technology to perfect what DLP can do for energy saving in the 21st century classroom. The MX819ST brings together uncompromised brightness, exquisite picture quality and optimized lamp life through innovative features. -
Eco blank mode
The eco blank mode allows teachers to blank the projection screen whenever they need to direct their students' focus back on them - or simply when the projector is not in use. When activated, this special feature dims the lamp power automatically, lowering the total power consumption by 70%. -
No source detected mode
The automatic switch to eco blank mode after the projector is turned on for over three minutes without a display source, eliminating unnecessary energy waste and prolonging the life of the projector lamp. -
Ultra-high contrast ratio
An ultra-high contrast ratio projects sharp images, even for high brightness projectors. Get better contrast and blacker blacks with a 13000:1 contrast ratio. -
0.5 W in standby mode
When inactive, the MX819ST complies with 2013 EU standards by keeping power consumption to a minimum using less than 0.5 W on standby, extending lamp life and reducing energy costs. -
Blu-ray Full HD 3D supported
BenQ MX819ST is built with latest DLP technology to support 3D functionality, allowing schools to bring an immersive learning experience to their students with a simple preparation of 3D glasses and 3D content from your Blu-ray player. -
Zero eye-blinding lights
The short-throw projection distance keeps the projector light from shining directl into your eyes, allowing you to keep your focus on your audience. -
Zero disruptions
Say goodbye to the shadows that often interrupt your presentation. With a projection distance this close, you and your audience can move freely without worrying about obstructions between the projector and the screen! -
LAN control with Crestron and PJ-Link
LAN control is designed to help IT managers perform day-to-day projector maintenance and repair tasks efficiently and effectively - offering them full access and control over every projector directly from their workstations. The MX819ST offers seamless support for the Crestron and PJ-Link LAN control system.
- BenQ MX819ST - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 13000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 270 Watt
- 28.73 cm x 23.26 cm x 11.44 cm
- 2.6 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3000 ANSI lumens
- Contrast Ratio
- 13000:1
- Image Size
- 152 cm - 762 cm
- Throw Ratio
- 0.61:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1600 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
- Closed Caption, PJlink, ecoFACTS, SmartEco Technology, Eco Blank
Lens
- Lens Aperture
- F/2.6
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 (management) , 1 x USB - 4 pin USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
- Included Accessories
- Lens cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security Slot Type
- Kensington security slot
- Voltage Required
- 270 Watt
- Power Consumption Stand by
- 0.5 Watt
- 28.73 cm
- 23.26 cm
- 11.44 cm
- 2.6 kg
- Sound Emission
- 32 dBA
- Sound Emission (Economic Mode)
- 28 dBA
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
