BenQ MX570 XGA LCD 3200 Lumens Projector
Quicklinx: 9RTHWS00 Mfr#: 9h.JCS77.14E
Brightness: 3200ANSI lumens
Portability: Portable
£450.67 ex VAT
£540.80 inc VAT
Featuring a brightness of 3,200 ANSI lumens, a high contrast ratio of 13,000:1 and an XGA resolution, the cost-effective and eco-friendly MX570 offers a stunning full-screen presentation with the finest details regardless of the ambient light level. It also supports HDMI and LAN control for better signal transmission and efficient projector management.
  • Saving more on power consumption with BenQ's SmartEco technology
    Offering lower TCO and optimized projection through dynamic power saving, uncompromised brightness, exquisite picture quality and optimized lamp life - SmartEco technology has perfected what a DLP projector can do. With this innovation, schools and corporates are able to save lamp power consumption and lower maintenance costs through dynamic power saving features while bringing an ultra-vivid viewing experience into every presentation.
  • SmartEco mode
    By detecting the input content to determine the amount of brightness required for optimum color and contrast performance, the SmartEco mode is able to reduce lamp power while delivering the finest image quality. No compromise!
  • Eco blank mode
    The automatic switch to Eco blank mode after the projector is turned on for over three minutes without a display source, eliminating unnecessary energy waste and prolonging the life of the projector lamp.
  • LampSave mode
    Less lamp replacements and maintenance translates into an overall lower cost of ownership. The LampSave mode does exactly that by adjusting the lamp power dynamically by content level to extend projector lamp life significantly by up to 50% as compared to normal mode.
  • Blu-ray Full HD 3D supported
    BenQ MX570 is built with DLP technology to support 3D functionality, allowing schools to bring an immersive learning experience to their students with a simple preparation of 3D glasses and 3D content.
  • LAN control with Crestron and PJ-Link
    LAN control is designed to help IT managers perform day-to-day projector maintenance and repair tasks efficiently and effectively - offering them full access and control over every projector directly from their workstations. The MX570 offers seamless support for the Crestron and PJ-Link LAN control system.
  • BenQ DLP projectors, long-lasting image perfection with DLP technology
    BenQ DLP projectors are built with enduring enjoyment in mind, ensuring razor-sharp clarity, ultra-readability and true-to-life color for years to come. It uses leading-edge DLP technology to reflect pure light from millions of micro mirrors on a DMD chip through advanced color wheels. Since the mirrors are colorless and protected within a nearly-sealed engine, BenQ DLP projectors have no aging problems and are virtually immune to image decay, consistently delivering picture excellence time and time again. In fact, after long time of intense usage, inserting a bulb produces image quality comparable to a brand-new projector.
  • Razor-sharp clarity with ultra-readability
    Enabling a 96% fill factor, DLP technology supplies pixel circuitry behind the pixel, thereby eliminating the thick dark bezels around individual pixels, which diminish color and detail. A higher fill factor and less black border translate to noticeably purer, more intense color and smoother image quality. BenQ DLP projectors also feature high contrast ratios for flawless rendering of small text, fine lines, and dark scene details. Blacks are deeper and overall image quality is more focused and clean. Your presentations will be easily readable and highly effective, even from the back row of a well-lit venue.
  • Vibrant, true-to-life colors
    Even in lit venues, BenQ DLP projectors achieve the optimal balance of brightness and color accuracy, with BrilliantColor technology additionally boosting true-to-life colors that captivate. BrilliantColor enables up to six-color processing. Your every presentation is rendered in pure, living splendor.
  • ecoFACTS label
    ecoFACTS can tell you how eco-friendly BenQ products are! Development of eco-friendly products, BenQ doesn't just want to comply with green regulations passively, but also to actively develop eco-friendly products! ecoFACTS declares BenQ's greatest efforts on the replacement of hazardous substances, material selection, packaging design, energy-saving design and other aspects of the products.
BenQ MX570 - DLP projector - portable - 3D
DLP projector
3D Capable
Brightness
3200 ANSI lumens
Contrast Ratio
13000:1
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
190 Watt
Bulb life cycle
Up to 4500 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
280 Watt
28.3 cm x 22.2 cm x 8.87 cm
1.9 kg
DLP projector
3D Capable
Ethernet
Projector
Brightness
3200 ANSI lumens
Contrast Ratio
13000:1
Image Size
152 cm - 762 cm
Throw Ratio
1.51 - 1.97:1
Resolution
XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
190 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
SmartEco Technology
Lens
Lens Aperture
F/2.59-2.87
Zoom Factor
1.3x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x USB - mini-USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management)
Remote control
1 x VGA cable
Nominal Voltage
280 Watt
Power Consumption Stand by
0.5 Watt
28.3 cm
22.2 cm
8.87 cm
1.9 kg
Sound Emission
33 dB
28 dB
9RTH C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
9RTH C2G 0.5m Select High Speed HDMI with Ethernet In Stock £6.18
9RTH C2G 5m Select High Speed HDMI with Ethernet In Stock £20.65
Brand: BenQ
Price Range Ex VAT: 300 - 500
