Featuring a brightness of 3,200 ANSI lumens, a high contrast ratio of 13,000:1 and an XGA resolution, the cost-effective and eco-friendly MX570 offers a stunning full-screen presentation with the finest details regardless of the ambient light level. It also supports HDMI and LAN control for better signal transmission and efficient projector management.
Saving more on power consumption with BenQ's SmartEco technology
Offering lower TCO and optimized projection through dynamic power saving, uncompromised brightness, exquisite picture quality and optimized lamp life - SmartEco technology has perfected what a DLP projector can do. With this innovation, schools and corporates are able to save lamp power consumption and lower maintenance costs through dynamic power saving features while bringing an ultra-vivid viewing experience into every presentation. -
SmartEco mode
By detecting the input content to determine the amount of brightness required for optimum color and contrast performance, the SmartEco mode is able to reduce lamp power while delivering the finest image quality. No compromise! -
Eco blank mode
The automatic switch to Eco blank mode after the projector is turned on for over three minutes without a display source, eliminating unnecessary energy waste and prolonging the life of the projector lamp. -
LampSave mode
Less lamp replacements and maintenance translates into an overall lower cost of ownership. The LampSave mode does exactly that by adjusting the lamp power dynamically by content level to extend projector lamp life significantly by up to 50% as compared to normal mode. -
Blu-ray Full HD 3D supported
BenQ MX570 is built with DLP technology to support 3D functionality, allowing schools to bring an immersive learning experience to their students with a simple preparation of 3D glasses and 3D content. -
LAN control with Crestron and PJ-Link
LAN control is designed to help IT managers perform day-to-day projector maintenance and repair tasks efficiently and effectively - offering them full access and control over every projector directly from their workstations. The MX570 offers seamless support for the Crestron and PJ-Link LAN control system. -
BenQ DLP projectors, long-lasting image perfection with DLP technology
BenQ DLP projectors are built with enduring enjoyment in mind, ensuring razor-sharp clarity, ultra-readability and true-to-life color for years to come. It uses leading-edge DLP technology to reflect pure light from millions of micro mirrors on a DMD chip through advanced color wheels. Since the mirrors are colorless and protected within a nearly-sealed engine, BenQ DLP projectors have no aging problems and are virtually immune to image decay, consistently delivering picture excellence time and time again. In fact, after long time of intense usage, inserting a bulb produces image quality comparable to a brand-new projector. -
Razor-sharp clarity with ultra-readability
Enabling a 96% fill factor, DLP technology supplies pixel circuitry behind the pixel, thereby eliminating the thick dark bezels around individual pixels, which diminish color and detail. A higher fill factor and less black border translate to noticeably purer, more intense color and smoother image quality. BenQ DLP projectors also feature high contrast ratios for flawless rendering of small text, fine lines, and dark scene details. Blacks are deeper and overall image quality is more focused and clean. Your presentations will be easily readable and highly effective, even from the back row of a well-lit venue. -
Vibrant, true-to-life colors
Even in lit venues, BenQ DLP projectors achieve the optimal balance of brightness and color accuracy, with BrilliantColor technology additionally boosting true-to-life colors that captivate. BrilliantColor enables up to six-color processing. Your every presentation is rendered in pure, living splendor. -
ecoFACTS label
ecoFACTS can tell you how eco-friendly BenQ products are! Development of eco-friendly products, BenQ doesn't just want to comply with green regulations passively, but also to actively develop eco-friendly products! ecoFACTS declares BenQ's greatest efforts on the replacement of hazardous substances, material selection, packaging design, energy-saving design and other aspects of the products.
- BenQ MX570 - DLP projector - portable - 3D
- DLP projector
- 3D Capable
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 13000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 280 Watt
- 28.3 cm x 22.2 cm x 8.87 cm
- 1.9 kg
- DLP projector
- 3D Capable
- Networking
- Ethernet
Projector
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 13000:1
- Image Size
- 152 cm - 762 cm
- Throw Ratio
- 1.51 - 1.97:1
- Resolution
- XGA - XGA (1024 x 768) (native) / 1920 x 1200 (resized)
- 4:3
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
- SmartEco Technology
Lens
- Lens Aperture
- F/2.59-2.87
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x network - RJ-45 , 1 x USB - mini-USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management)
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Voltage Required
- 280 Watt
- Power Consumption Stand by
- 0.5 Watt
- 28.3 cm
- 22.2 cm
- 8.87 cm
- 1.9 kg
- Sound Emission
- 33 dB
- Sound Emission (Economic Mode)
- 28 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
