Brilliantly powerful yet simple to use, BenQ MW705 business projector turns your bright ideas into effective presentations. Its sleekly modern design quietly delivers 4000 lumens of high brightness with the ease of one-touch controls, even for wireless streaming. Look no further for the smartest solution in professional projection.
- BenQ MW705 - DLP projector - portable - 3D
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 4000 ANSI lumens
- Contrast Ratio
- 13000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- 240 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 4000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 350 Watt
- 33.1 cm x 24.62 cm x 11.44 cm
- 3 kg
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 4000 ANSI lumens
- Contrast Ratio
- 13000:1
- Image Size
- 162 cm - 762 cm
- Throw Ratio
- 1.55 - 1.7:1
- Resolution
- WXGA - WXGA (1280 x 800) (native) / 1920 x 1200 (resized)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- 240 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
- sRGB colour profile, Eco Blank, MHL compliance, SmartEco Mode, Razor-Sharp
Lens
- Lens Aperture
- F/2.56-2.68
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Horizontal, vertical
- Vertical Keystone Correction
- -40 / +40
- Horizontal Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x HDMI - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone 3.5 mm , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone 3.5 mm , 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x USB - 4 pin USB Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
- Included Accessories
- Carrying case, lens cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Power Source
- AC
- Voltage Required
- 350 Watt
- Power Consumption Stand by
- 0.5 Watt
- 33.1 cm
- 24.62 cm
- 11.44 cm
- 3 kg
- Sound Emission
- 33 dBA
- Sound Emission (Economic Mode)
- 29 dBA
