BenQ MW533 WXGA DLP 3300 Lumens Meeting Room Projector
Quicklinx: D8L0WS00 Mfr#: 9H.JG877.33E
Tailor-made for simple, reliable performance in meeting rooms day in and day out, BenQ MW533 combines bright big-picture quality, intuitive hassle-free operation, and convenient digital connectivity with environmentally conscious power savings and budget-friendly low total cost of ownership.
3,300 lumens of high brightness provide comfortable lights-on presentations in well-lit meeting rooms to promote discussion, collaboration, and note-taking. The high luminance boosts picture quality with vibrant color for pictures and videos as well as crisp text and fine details.
Powerful 15,000:1 native contrast enabled by state-of-the-art DLP technology and all-glass optical lens systems deliver ultimate clarity, smooth gradational mid-tone color transitions, and razor-sharp readability for compelling corporate visual communication.
  • Smart design for daily presentations
  • Outstanding high brightness for clear presentations in bright environments
  • High native contrast for superior readability and subtle gradations
  • Multiple HDMI and VGA inputs for universal connectivity
    Dual HDMI inputs in addition to dual VGA inputs are purpose-engineered to host multiple presenters and their laptop or mobile devices without a second thought. Multiple inputs enable meeting participants, teachers, and students to collaborate instantly without complicated adapters or time-consuming IT support.
  • Vertical keystone correction for perfectly aligned images
    Countering the trapezoid effect when the projector must be placed off-center, such as simple placement on top of a table, the vertical keystone function adjusts the image for a professionally squared image. Keystone correction makes it simple to project ideally aligned images from a variety of locations.
  • Convenient outer adjustment feet
    Far superior to projectors with only one adjustment foot, the triple adjustment feet significantly enhance flexibility in a wide variety of meeting rooms, with the additional feet placed at the corners or the projector to facilitate easy movement.
  • Designed for convenient room-to-room portability
    A sleek, compact industrial design with a sculpture patterned cabinet resists dirt and fingerprints as the projector is moved from one room to another, along with new intuitive keypad and remote control layout to simplify picture adjustment to the new room.
BenQ MW533 - DLP projector - portable - 3D
DLP projector - 720p
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DarkChip 3
Brightness
3300 ANSI lumens
Contrast Ratio
15000:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Bulb type
UHP 203 Watt
Bulb life cycle
Up to 4500 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video (NTSC, SECAM, PAL)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
260 Watt
33.24 cm x 24.13 cm x 9.9 cm
2.41 kg
3D Capable
Projector
Microdisplay
DarkChip 3
Brightness
3300 ANSI lumens
Contrast Ratio
15000:1
Image Size
152 cm - 762 cm
Throw Ratio
1.55 - 1.86:1
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Max Sync Rate (V x H)
120 Hz x 102 kHz
Bulb type
UHP 203 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction
OSD Languages
Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
SmartEco Technology, Eco Blank, Razor-Sharp, Long Lasting
Lens
Lens Aperture
F/2.46-2.66
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Video Input
TV System
NTSC, SECAM, PAL
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
Speakers
1 x mixed channel
2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
Remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), security bar
Security Slot Type
Kensington security slot
Power Source
AC
260 Watt
Power Consumption Stand by
0.5 Watt
33.24 cm
24.13 cm
9.9 cm
2.41 kg
Sound Emission
32 dB
28 dBA
