Tailor-made for simple, reliable performance in meeting rooms day in and day out, BenQ MW533 combines bright big-picture quality, intuitive hassle-free operation, and convenient digital connectivity with environmentally conscious power savings and budget-friendly low total cost of ownership.
3,300 lumens of high brightness provide comfortable lights-on presentations in well-lit meeting rooms to promote discussion, collaboration, and note-taking. The high luminance boosts picture quality with vibrant color for pictures and videos as well as crisp text and fine details.
Powerful 15,000:1 native contrast enabled by state-of-the-art DLP technology and all-glass optical lens systems deliver ultimate clarity, smooth gradational mid-tone color transitions, and razor-sharp readability for compelling corporate visual communication.
Smart design for daily presentations
Tailor-made for simple, reliable performance in meeting rooms day in and day out, BenQ MW533 combines bright big-picture quality, intuitive hassle-free operation, and convenient digital connectivity with environmentally conscious power savings and budget-friendly low total cost of ownership. -
Outstanding high brightness for clear presentations in bright environments
3,300 lumens of high brightness provide comfortable lights-on presentations in well-lit meeting rooms to promote discussion, collaboration, and note-taking. The high luminance boosts picture quality with vibrant color for pictures and videos as well as crisp text and fine details. -
High native contrast for superior readability and subtle gradations
Powerful 15,000:1 native contrast enabled by state-of-the-art DLP technology and all-glass optical lens systems deliver ultimate clarity, smooth gradational mid-tone color transitions, and razor-sharp readability for compelling corporate visual communication. -
Multiple HDMI and VGA inputs for universal connectivity
Dual HDMI inputs in addition to dual VGA inputs are purpose-engineered to host multiple presenters and their laptop or mobile devices without a second thought. Multiple inputs enable meeting participants, teachers, and students to collaborate instantly without complicated adapters or time-consuming IT support. -
Vertical keystone correction for perfectly aligned images
Countering the trapezoid effect when the projector must be placed off-center, such as simple placement on top of a table, the vertical keystone function adjusts the image for a professionally squared image. Keystone correction makes it simple to project ideally aligned images from a variety of locations. -
Convenient outer adjustment feet
Far superior to projectors with only one adjustment foot, the triple adjustment feet significantly enhance flexibility in a wide variety of meeting rooms, with the additional feet placed at the corners or the projector to facilitate easy movement. -
Designed for convenient room-to-room portability
A sleek, compact industrial design with a sculpture patterned cabinet resists dirt and fingerprints as the projector is moved from one room to another, along with new intuitive keypad and remote control layout to simplify picture adjustment to the new room.
- BenQ MW533 - DLP projector - portable - 3D
- DLP projector - 720p
- 3D Capable
- Yes (3D glasses sold separately)
- Microdisplay
- DarkChip 3
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 15000:1
- Resolution
- WXGA (1280 x 800)
- Native Aspect Ratio
- 16:10
- Bulb type
- UHP 203 Watt
- Bulb life cycle
- Up to 4500 hour(s) - normal mode , Up to 10000 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 260 Watt
- 33.24 cm x 24.13 cm x 9.9 cm
- 2.41 kg
- 3D Capable
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3300 ANSI lumens
- Contrast Ratio
- 15000:1
- Image Size
- 152 cm - 762 cm
- Throw Ratio
- 1.55 - 1.86:1
- Resolution
- WXGA - WXGA (1280 x 800)
- 16:10
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- UHP 203 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
- SmartEco Technology, Eco Blank, Razor-Sharp, Long Lasting
Lens
- Lens Aperture
- F/2.46-2.66
- Zoom Factor
- 1.2x
- Keystone Correction Direction
- Vertical
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 2 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x HDMI - 19 pin HDMI Type A , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x serial RS-232 - 9 pin D-Sub (DB-9)
- Included Accessories
- Remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Security lock slot (cable lock sold separately), security bar
- Security Slot Type
- Kensington security slot
- Power Source
- AC
- Voltage Required
- 260 Watt
- Power Consumption Stand by
- 0.5 Watt
- 33.24 cm
- 24.13 cm
- 9.9 cm
- 2.41 kg
- Sound Emission
- 32 dB
- Sound Emission (Economic Mode)
- 28 dBA
