BenQ MU706 is just what you need to perfect your presentation in all settings. Boasting 4000 ANSI lumens and 20000:1 high contrast ratio, this WUXGA projector also offers auto vertical keystone correction for diverse display options to keep your presentations looking great!
- BenQ MU706 - DLP projector - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 4000 ANSI lumens
- Contrast Ratio
- 20000:1
- Resolution
- WUXGA (1920 x 1200)
- Native Aspect Ratio
- 16:10
- Colour Support
- 1.07 billion colours
- Bulb type
- 240 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 7500 hour(s) - economic mode
- Video Input
- RGB, S-Video, composite video, component video (NTSC, SECAM, PAL)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 350 Watt
- 33.1 cm x 24.62 cm x 12.94 cm
- 3.3 kg
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 4000 ANSI lumens
- Contrast Ratio
- 20000:1
- Image Size
- 76.2 cm - 762 cm
- Throw Ratio
- 1.15 - 1.49:1
- Resolution
- WUXGA - WUXGA (1920 x 1200)
- 16:10
- Colour Support
- Max Sync Rate (V x H)
- 120 Hz x 102 kHz
- Bulb type
- 240 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hindi, Hungarian, Czech, Croatian, Indonesian, Thai, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Romanian, Japanese, Korean
- 3D Color Management, Auto Power Off, Eco Blank, MHL compliance, SmartEco Mode, Razor-Sharp, Long Lasting
Lens
- Lens Aperture
- F/2.59-2.87
- Zoom Factor
- 1.3x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- TV System
- NTSC, SECAM, PAL
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video, MHL
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 2 Watt
- Speakers
- 1 x mixed channel
- 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x S-video input - 4 pin mini-DIN , 1 x composite video/audio input - RCA x 3 , 1 x audio line-in - mini-phone 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x USB (power only) - 4 pin USB Type A , 1 x USB - 4 pin mini-USB Type B , 1 x audio line-out - mini-phone 3.5 mm , 1 x HDMI - 19 pin HDMI Type A
- Included Accessories
- Lens cover, wireless remote control
- Cables Included
- 1 x VGA cable
- Security Features
- Power Source
- AC
- Voltage Required
- 350 Watt
- Power Consumption Stand by
- 0.5 Watt
- 33.1 cm
- 24.62 cm
- 12.94 cm
- 3.3 kg
- Sound Emission
- 31 dB
- Sound Emission (Economic Mode)
- 28 dB
